Hesstifer
Photomerge Result Vertical... Should Be Horizontal
Jul 26, 2012 8:08 AM
Tags: #problem #cs5 #result #photomerge #vertical
I'm trying to stitch 3 photos vertically-shot photos together (Photoshop CS5 extended), hoping the end results would be horizontal, but the following occurs:
The photo that it puts on the top shuld actually be the right-most photo in the pano.
I tried photomerging the exact same three photos with a darker exposure, and it turned out perfectly.
I've searched and searched for answers but haven't found anything (probably because I'm not sure how to properly describe the problem).
Many thanks,
Greg
    Jul 26, 2012 8:23 AM   in reply to Hesstifer
    I think it can’t find any matches between the top picture at the bottom two.  The ripples in the water would be different, the sky is blown out, and just that little bit of land on the horizon is common, which isn’t enough to get a good match.
    With a darker exposure the clouds in the sky would provide more match points.
    I use AutoPanoGiga (pay for software) to do my panoramas.  It has the benefit of allowing guided match-point determination where you could high-light the horizon land in the two adjacent photos and it’d find matches, then.
    http://www.kolor.com/
    Jul 26, 2012 8:36 AM   in reply to Hesstifer
    I tried photomerging with your images and got the same result as you. Like ssprengel said, there wasn't much in common in the photos. This link may be a helpful reference to you when using photomerge later on:
    http://help.adobe.com/en_US/photoshop/cs/using/WSfd1234e1c4b69f30ea53e 41001031ab64-75e8a.html
    Jul 26, 2012 9:07 AM   in reply to Hesstifer
    The sky and the water look nice, except the brightness discontinuity you’ve acknowledged; however, the grass and the boatman aren’t vertical. Maybe a different projection would do a better job?
    Are you starting with JPGs or raw files?  Are you blending the HDR by hand or through an automated process?  Did you shoot 3 exposures in each position for a total of 9 images for your HDR panorama?
    Instead of selectively burning the sky in PS, I would probably have opened all three files in Camera Raw and used the same Highlights Reduction setting to bring down the sky a bit evenly across the entire sky, avoiding the discontinuity you have to work around.
    Jul 26, 2012 7:10 PM   in reply to Hesstifer
    Here are a couple of other things to try:
    1. Use file>Scripts>Load Files into Stack and leave the align button at the bottom unchecked.
       Expand the canvas size, manually align the photos as best you can and then select all the layers and use Edit>Auto Blend Layers.
    2. Try the optional interactive layout (Photomerge UI) for cs5:
    http://helpx.adobe.com/photoshop/kb/plug-ins-photoshop-cs5.html
    How to use:
    http://help.adobe.com/en_US/photoshopelements/using/WS287f927bd30d4b1f ef992ca12e28aa8015-7fc6.html
