Would very much appreciate any comments/suggestions re. this proposed build.
I would look at a different PSU. This model is not modular, only Bronze labeled, hampered by four separate 12V rails and is unclear about the internal components. I would have a serious look at the Corsair AX series or Seasonic, all fully modular and at least Gold+ rated.
With the Crucial Balistix sticks, which are probably Micron based sticks going by their CAS ratings, you can not populate the 8 slots without a good likelihood of getting into stability problems. I would suggest G.Skill Ripjaws-Z series (max 1.5V) or going for the 8 x 4GB Samsung (1.35V) sticks.
If budget allows go for the i7-3930K CPU. Have a look at what I'm building: Adobe Forums: Planning / building a new system. Part 1
Appreciate the input Harm. I will run this by the guys doing the build for me and see wha they come up with.
I have theCorsair PSU, Harms mentions, and so far it has been just great.
I beleive that some people might overlook the signifigance of the PSU. It is a very importat part of the PC, and if you get into hardware trouble with a high quality PSU, it might be easier to point at other components.
Ulf
I have also had great service from Optiarc, but then have also had great service from my LG DVD multi-drive/burner. Both have been flawless in their operation.
Pioneer was once highly recommended, but recently, the user reports have not been THAT good. Not sure if there were some weak models, or if things changed?
Otherwise, I have no comments, other than good luck, and enjoy your new box.
Hunt
Couple of follow up questions...
I have decided to upgrade the processor and am wondering what the "observable" (for lack of a better term) difference in peformance between these more expensive units would be?
To upgrade from the current spec:
Intel Core-i7 Socket 2011 3820 3.6GHz 4-Core
To:
Intel Core-i7 3930K 3.2GHz 6-Core Unlocked (add $280.00)
or:
Intel Core-i7 3960X Extreme 3.3GHz 6-Core Unlocked (add $760.00)
Same general question re. the SSD boot/program drive. Other than a faster boot time, do the solid state drives offer significan advantages with PPro CS6?
Willing to shell out the extra $$$ but would like to get some idea as to bang for the buck. ![]()
Rough estimate of the 3930K versus 3820 is about 20% performance improvement because of 6 cores versus 4 and 12 MB L3 cache versus 10 MB, depending on your workflow and source material. Maybe a bit higher with complex codecs and less with simple codecs.
Performance difference between the 3930K and 3960X is very small and not worth the price IMO. Both 39xx CPU's are unlocked and if you overclock them a bit to say 4.5 GHz, there is no discernible performance difference to warrant the extra cost.
SSD's offer no advantage in PR performance, only as you correctly stated in boot time and loading programs.
Great-- thanks again. Looks like it's the 3930K and I think I'll stick w/ a 500GB standard 7200 HD as well. I'll come back with some benchmark tests when ready to roll.
Looks like my multiple Adobe IDs from the distant past has confused this thread. "Tymb" and "Tym_Ribich" are both ME! I'll blame Adobe for messin' things up back when the forum format changed and I couldn't figure out what in he** was going on... ![]()
I'll try to be more conisistent in the future!
