Just wondering...has anyone ever programmed a button to retrieve and display local PC info such as:
Computer Make/Model
Serial number
OS
Computer Name
Amount of installed memory
Build Date
Video card type
Current User logged into system
Local Administrators
Installed printers
Default printer
HD drive mappings
ODBC Drivers
I have scripts that were written in Visual basic but need a comparable Javascript solution for Designer
Please advise - thank you in advance.
you cannot retrieve those information with Acrobat's JavaScript except the printer names und the user name.
var l = app.printerNames.length
for ( var i = 0; i < l; i++)
console.println("(" + (i+1) + ") " + app.printerNames[i]);
The user name requires an folder level script as this property need a trusted enviroment be be read.
var UserName = app.trustedFunction(function(doc)
app.beginPriv();
var User = this.xfa.form.Form1.Page1.UserNameField1;
User.rawValue = this.identity.loginName;
app.endPriv();
Thank you Radzmar,
So you don't think there's a way to retrieve the otehr sought after info (besides printer and user name), via Lifecycle JavaScript even if folder-level JS was used as well?
I know much of this info is contained within the system proprieties - I was just wondering if there was a means of accessing it locally.
Shaun
I am not sure if you will be able to access all of the information, but accessing information like the current user would be considered a security concern.
You could need a trusted function, which is script in a JavaScript file that is placed in the Acrobat folder of EVERY computer accessing the form.
You can do a search for trusted function on the forums, but here are a few:
http://forums.adobe.com/message/2189021#2189021
http://forums.adobe.com/message/2366415#2366415
http://forums.adobe.com/message/2326803#2326803
Hope that helps,
Niall
Hi Niall,
I certainly follow you on this...
But qick question... I grasp the concept, but is the trusted function always the same, or does it vary based on what you're trying to accomplish?
So...is the function contained within the js universal (always the same script), or does it change?
Shaun
