Indesign CS4 save issue on Win xp SP3
Jul 24, 2012 12:51 AM
When working with existing Indesign CS4 documents, when you click "Save" the "Save As" dialogue box appears. Any newly created documents save correctly?
Other users can open the same issue documents and save as per normal so it does not seem to be realted to the documents.
    Jul 24, 2012 4:36 AM   in reply to K1ngBaz
    What's the history of these files? The first time any file is opened in a newer version and is converted you get a save as dialog to prevent accidentally overwriting the old version. This can sometimes happen after a program update, too, so did you recently update ID?
    Another possibility is the use of a custom keyboard shortcuyt set that has remapped Ctrl + S to save As if you are using shortcuts rather than the menu.
    Jul 27, 2012 4:32 AM   in reply to K1ngBaz
    Is this a fully patched version of CS4?
    Bob
    Jul 30, 2012 6:10 AM   in reply to K1ngBaz
    You mentuioned the possibility that these were conversions from Quark. The first time you hit Save with any conversion you would get the save as dialog, and it isn't clear if the problem aoours at that point, or later, after another user has already done the initial save as.
    It's also not unusual for a converion to have some quirkiness in general. I'd try the export to .inx from CS4 and see if it makes a difference: Remove minor corruption by exporting
    And if not, try trashing the prefs for that user: Replace Your Preferences
