Dear All,
I have made some images into animated buttons that enlarge on rollover, can someone help me to bring each layer to the front on rollover, I am working in CS3 with actionscript 2
Please check & commend me WEBLINK
For AS2 you should look into using the swapDepths() method to have the two objects switch which is on top. Here is a link that might help you...
http://help.adobe.com/en_US/as2/reference/flashlite/WS5b3ccc516d4fbf35 1e63e3d118ccf9c47f-7f70.html
thanks for your reply.
I am incorporate this code in my time line
myMC1_mc.onRelease = function() {
this.swapDepths(myMC2_mc);
myMC2_mc.onRelease = function() {
this.swapDepths(myMC1_mc);
entire animation is stopped. I am try to in mouse over my animation is happend also bring to front another movie clip myMC2_mc
how can i do it.
please help anybody know how can i do this
I am incorprate this code nothings is happend
USAGE:
myMC.bringToFront();
myMC.bringToFront({protect:[myMC2, myMC3]});
The second form allows you to protect certain movieclips from having
their stacking order affected. This is useful if you have some movieclips
you want to stay in front of everything else. You pass the actual
movieclip objects, not a string of the movieclip name.
MovieClip.prototype.bringToFront = function(optionsObj:Object):Void{
// define an array to hold a snapshot of the display list
var displayList:Array = new Array();
// traverse the current parent object's children
for (var i:String in this._parent){
// and only capture movieclips (not other properties) whose depth is greater than
// the movieclip we're bringing to the front.
// the _parent == this._parent is there to get around a strange bug I encountered
// where we were digging into children's descendants. don't know why.
if (typeof (this._parent[i]) == "movieclip"
&& this._parent[i]._parent == this._parent
&& this._parent[i].getDepth() > this.getDepth()){
var includeItem:Boolean = true;
// check to make sure this item is not one of the "protected" items
for (var j:Number = 0; j < optionsObj.protect.length; j++){
if (this._parent[i] == optionsObj.protect[j]){
includeItem = false;
break;
// store it in the array.
if (includeItem) displayList.push(this._parent[i]);
// for (x in y) usually traverses the object backwards, so here we're
// iterating over displayList in reverse, and just swapping the
// original object's depth all the way up the list. Can't really think
// of a more efficient way of doing this.
for (var i:Number = displayList.length-1; i>=0; i--){
this.swapDepths(displayList[i]);
