How can I create poly coords from an AI file?
Jul 25, 2012 2:06 PM
Tags: #illustrator #poly-coords #image-map
I have an ai file containing a U.S. map with each state on its own layer and path. I need to be able to create the poly coords for each state for use in an image map.
Is this possible and how?  Thank you in advance for assistance.
m
    Jul 25, 2012 11:24 PM   in reply to TheRealUpWorks
    Image maps for web design are handled inside the HTML code. That being so, nobody would use genuine detailed vector data for it. Simply re-trace the contours with a few points in Dreamweaver or whatever web design tool you use. If that's nort good enough, an SVG with interaction might also work.
    Mylenium
    Jul 26, 2012 10:28 AM   in reply to TheRealUpWorks
    http://forums.adobe.com/message/4388468#4388468
    (There should be a longer example floating around this forum, perhaps someone else remembers the crucial magic phrase to google it.)
    Jul 26, 2012 11:54 AM   in reply to TheRealUpWorks
    This seems to work from simple tests.
    #target illustrator
    var textFile = File('~/Desktop/AI.txt');
    var idoc = app.activeDocument;
    var idocText = '';
    var layers = idoc.layers;
    for (j=0; j<layers.length; j++) {
        var ipath = layers[j].pathItems[0];
        var itext = idoc.layers[j].textFrames.add();
        var pp = [];
        for (i=0; i<ipath.pathPoints.length; i++) {
            pp.push(ipath.pathPoints[i].anchor);
        itext.contents = layers[j].name + ":" +  ("\r") + pp.join ("\r");
        pp = null;
    for (var i = 0; i < idoc.textFrames.length; i++)
              idocText += idoc.textFrames[i].contents + '\r';
    textFile.open('e');
    textFile.write(docText);
    textFile.close();
    idoc.textFrames.removeAll();
    Jul 26, 2012 2:03 PM   in reply to TheRealUpWorks
    Ai uses points as its internal referencing system and the 0,0 point is at the upper left of the page. A point is 1/72 of an inch (from Postscript page description language).
    Jul 26, 2012 2:40 PM   in reply to TheRealUpWorks
    As far as AI is concerned thay are the same. How are you determining the x and y your are describing?
    Jul 26, 2012 3:11 PM   in reply to TheRealUpWorks
    No, I mean your pixel x-y.
    Jul 26, 2012 4:34 PM   in reply to TheRealUpWorks
    The number you see are given in a coordinate system which reads from bottom left (the old way); the numbers from the script are from the top left. So for the corresponding you have to add a minus number equal to the height of your artboard. Makes lots of sense, right?
    Jul 26, 2012 6:42 PM   in reply to TheRealUpWorks
    you should get something like this, try it with a simple shape, to see how it works.
    look at the second coords (0, -67) and note the position of the 9-point Ref point in the Transform panel, it gives you X: 0 pt, Y: 67 pt. As Larry mentioned, the sign difference is due to a change in the system from CS4 to CS5, I did not write logic to deal with it at that time.
    Jul 27, 2012 9:54 AM   in reply to TheRealUpWorks
    the script shows "global" position, you probably have "Artboard Rulers". Right-Click on the Rulers to make sure.
    Jul 27, 2012 10:08 AM   in reply to TheRealUpWorks
    mmh...create a new document and add a simple shape to see if it works, and if it does check the rulers if they're still greyed out.
    Jul 27, 2012 10:27 AM   in reply to TheRealUpWorks
    not that I know of, if you change to Global, does it work as expected?
    Jul 27, 2012 11:08 AM   in reply to TheRealUpWorks
    cool, you're welcome
