How to make a back button?
Jul 27, 2012 7:25 AM
I want to make a back button, but I'm not really sure how to do this. I did some research and some people said you need an array. I've never made an array before. Everyone of my frames have a label and multiple ways to get to that frame. Can anyone help me with this? Any help would be appreciated, thank you.
    Jul 27, 2012 8:24 AM   in reply to John Delamotte
    The array will be a list of your steps
    define the array:
    var myBackList:Array=new Array();
    now every time it you change to another frame, add to the list (array) the label name of the frame
    i.e.
    myButtonGoToFirstSection.addEventListener(MouseEvent.CLICK, gotoFirstSection)
    function gotoFirstSection(e:MouseEvent):void{
             gotoAndStop("FirstSeccion")
              myBackList.push("FirstSeccion") //this add the the label to the array
    then the code to the back button is:
    myBackButton.addEventListener(MouseEvent.CLICK, goBack)
    function goBack(e:MouseEvent):void{
              gotoAndStop(myBackList.pop())
    Jul 27, 2012 10:21 AM   in reply to John Delamotte
    yes, you must add to each button, the array is a stack and added in the order they arrive, to "back" you will always take the last.
    The pop method, gets the last value and delete it
    Aug 14, 2012 1:01 PM   in reply to John Delamotte
    You are not using the same code above,  can you show your code?
    Aug 14, 2012 2:10 PM   in reply to John Delamotte
    stop();
    bioBut.addEventListener(MouseEvent.CLICK, gotoBiographies);
    overviewBut.addEventListener(MouseEvent.CLICK, gotoOverview);
    commemorationBut.addEventListener(MouseEvent.CLICK, gotoCommemoration);
    GettingStartedButt.addEventListener(MouseEvent.CLICK, gotoAboutTheLesson);
    myBackButton.addEventListener(MouseEvent.CLICK, goBack);
    function gotoBiographies(event:MouseEvent):void {
        gotoAndStop("bios");
        myBackList.push("bios");
        trace(myBackList)
    function gotoOverview(event:MouseEvent):void {
        gotoAndStop("overview");
        myBackList.push("overview");
        trace(myBackList)
    function gotoCommemoration(event:MouseEvent):void {
        gotoAndStop("commemorationFrame");
        myBackList.push("commemorationFrame");
        trace(myBackList)
    function gotoAboutTheLesson(event:MouseEvent):void {
        gotoAndStop("aboutTheLesson");
        myBackList.push("aboutTheLesson");
        trace(myBackList)
    function goBack(e:MouseEvent):void {
        trace(myBackList);
        var frameGo:String=myBackList.pop();
        (currentLabel==frameGo)?gotoAndStop(myBackList.pop()):gotoAndStop(fra meGo);
        trace(myBackList);
        trace("---------");
