Hi all,
I am trying to assign different drives for the cache drives.
By default, it shows c/data/temp
When i select BROWSE, it only allows me to select folders in my C drive.
There are 3 cache drives paths in AE 6, It only allows me to change 1 of them to another drive other than C
Is anyone else having this issue?
thanks for the quick reply!
I have 5 drives that are all sata (no raids yet) C, M, N, J, Z all are 1 TB each
This is strange, Up until last night, i was able to select the M drive as a cache but the other 2 cache paths only allowed the "USERS NAME" icon which opens to all C drive stuff.
But now, I added another drive tonight, and now AE won't allow me to select ANY other path but the c Drive.
I am going NUTS!
Also, yes there are all available in explorer, my computer, etc.
The only icon i get is the "PC name" with a drop down that expands to Destop, my document, etc.. but no MY COMPUTER icon
Temporarily unmount the new drive in your disk management tool and try again. Could be that it shuffled up your drive letters and now Windows is using a wrong remebered file dialog. You can also flush that stuff from your registry (something with MRU and AfterFX.exe in your user-specific branch somewhere, should be HKEY_Current_User\Software\Microsoft\Windows\Current Version etc. or somethiong like that...)
Mylenium
well I did "rename" all the drive letters after i installed the other drive. i will look into that.
But remember, before I added the additional drive, I was only able to change 1 of the 3 cache paths that adobe has.
The other 2 did not show a MY Computer Icon..
I think i am going to call adobe
Yeah you'r right. I just looked at my CACHE folder in Cinema 4D, and its missing the MY COMPUTER drives as well.
It seems to be a windows thing But, i was able to TYPE the new path in Cinema 4D and it worked.
However, Although AE shows the path (c:\users\Lou\AppData\Temp),
I can't retype in a different path.
I went into the PREFS txt file, found the Cache path and changed it from there,
but as soon as AE starts, it overwrites it back to it's default path.
Does anyone know how I can change this path via Pref files,XLM file, etc..????
That shouldn't happen. If it does, it means whatever folder you assign is not accessible and it basically takes us back to where we started - you have a permissions problem. Reset user permissions and file ownership on all your drives. Right-click --> Properties --> Security tab.
Mylenium
Ah crap..no good, I have them all set to FULL in the permissions
. but interesting....in the preferences inside Cinema 4D, any 'path" browse button is also missing the MY COMPUTER icons but if I wanted to create a texture and used the "browse" button, it works fine.
I guess certain "browse" buttons open up different windows. I am at a lost for words at this point
Ok incase i run into this issue again, i am keeping the answer on this forum:
I SOLVED IT!
I had to UNCHECK... ENABLE DISK CACHE first.
Then, go into the preference txt file, change the path & save.
When back in AE, the path is changed (greyed out at the moment)
once enabled, the path was changed AND..all off my drive choices where all there in the browse folder.
Yippy!
