G'day
(This has also been posted on StackOverflow)
Say I have this code:
function doFileStuff(){
var file = "";
try {
file = fileOpen(filePath);
// do stuff with file
finally {
fileClose(file);
If the fileOpen() process fails, the fileClose() call will error. What I need to do is this sort of thing (pseudocode):
if (isFile(file)){
fileClose(file);
I know I can test if file is an empty string still, and this works for me here, but it's not testing what I should be testing: whether file is a file handle. I can check the object's Java class, but this again sounds a bit hacky to me, and there should be a CFML way of doing it.
There should be something like just isFile(), shouldn't there? I can't find anything like this in the docs.
Any thoughts / tips? I have gone into more depth in my investigations on my blog. it's too wordy for here.
Cheers for any help.
Adam
That would just defer the issue.. fileOpen() doesn't return a boolean, so I can't go:
if (fileOpen(filePath)){
fileClose(file);
fileOpen() returns a file object; or nothing if it fails. The whole thing is to identify whether it's a file. That's the question.
As per my original, it's dead easy to work around, provided one leverages known side effects of the situation (original variable state; that if it's a file it exposes some public properties; that one can doa getClass() on it via Java, etc), but one shouldn't have to work around something as fundamental as this. So I was wondering if I had missed something.
Seemingly not (based on feedback I've had from various quarters).
Adam
