I've created projects for clients and the first slide of each project is a slide video and around 50 seconds in, a button pops up so the user can click through to a PDF if they want.
However, each project has autoplay unchecked. so when the user first sees the video frame with the play button, the PDF link button is also there. Why is that?
Please see the image:
Please help! I would like this resolved for the client ASAP
Many thanks in advance
If you are using PDF output, you cannot remove this button on the first slide. The AutoPlay option does not apply to PDF output.
Hi RodWard,
The project is being published to Adobe Connect - so not as PDF. And the autoplay option is unchecked.
