Flash Player fails to register on 3 PCs!
Jul 24, 2012 2:38 PM
This is maddening... Here I am prompted in the past couple days to update Flash Player on my PCs however, the installation fails to register on 3 of them.
I am running Windows 7 64bit on all 3, IE8 on 2 and IE9 on 1.  Same issue with all 3!
I have followed the installation support instructions, downloaded the Flash Uninstalled, downloaded the latest Flash version, re-installed and the same thing continues to happen.
How does one fix this?  This is crazy!
    Jul 24, 2012 6:12 PM   in reply to tonymuffin
    "Failed to register" is a permission issue, usually in the Windows registry.
    Did you run the installation as an Administrator user?  Or did you allow the background update, which should not require an Admin user?
    The ultimate fix for permission issues is described in http://forums.adobe.com/thread/987370
    Jul 25, 2012 5:48 PM   in reply to tonymuffin
    Can you post the contents of a FlashPlayer.log file in either C:\Windows\system32\Macromed\Flash or C:\Windows\syswow64\Macromed\Flash or both?
    Jul 27, 2012 8:32 PM   in reply to tonymuffin
    You can paste using the standard Windows keyboard shortcut Ctrl+V.
    Jul 28, 2012 12:07 AM   in reply to tonymuffin
    I don't understand; what happens when you try?
    Here, I am just pasting the contents of my FlashInstall.log file...
    =O====== M/11.3.300.268 2012-07-27+00-58-22.623 ========
    0000 [I] 00000010 "C:\Users\PWILLE~1\AppData\Local\Temp\{1A5228D7-8420-41E2-95DF-7033ED DA351E}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
    0001 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    0002 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
    0003 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_3_300_268.ocx
    0004 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_268_ActiveX.e xe
    0005 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_268_ActiveX.d ll
    0006 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    =X====== M/11.3.300.268 2012-07-27+00-58-26.587 ========
    =O====== M/11.3.300.268 2012-07-27+00-58-47.927 ========
    0000 [I] 00000010 "C:\Users\PWILLE~1\AppData\Local\Temp\{FE0E85F8-C5B5-4227-B233-B5D230 F2C815}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
    0002 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
    0003 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
    0004 [W] 00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
    0005 [W] 00001036 Software\Mozilla\Waterfox\extensions/Plugins 2
    0006 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0007 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0008 [W] 00001036 Software\Opera Software/Plugin Path 2
    0009 [W] 00001036 Software\Opera Software/Plugin Path 2
    0010 [I] 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_3_300_268.dll
    0011 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_268_Plugin.ex e
    0012 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
    =X====== M/11.3.300.268 2012-07-27+00-58-51.389 ========
    =O====== M/11.3.300.268 2012-07-27+00-58-13.664 ========
    0000 [I] 00000010 "C:\Users\pwillener\Downloads\install_flash_player_11_active_x(1).exe "
    0002 [I] 00000011 1
    0003 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_3_300_268.ocx
    0004 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.e xe
    0005 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.d ll
    0007 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
    0008 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
    0009 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
    0010 [W] 00001106
    0011 [W] 00001106
    0012 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
    =X====== M/11.3.300.268 2012-07-27+00-58-35.371 ========
    =O====== M/11.3.300.268 2012-07-27+00-58-40.360 ========
    0000 [I] 00000010 "C:\Users\pwillener\Downloads\install_flash_player_11_plugin(1).exe"
    0002 [I] 00000011 1
    0004 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
    0005 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0007 [W] 00001036 Software\Opera Software/Plugin Path 2
    0009 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_3_300_268.dll
    0010 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_Plugin.ex e
    0011 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
    0013 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
    0014 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
    0015 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_3_300_268.exe
    0016 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
    0017 [W] 00001106
    0018 [W] 00001106
    0019 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
    Message was edited by: Pat Willener - added the 32-bit log as well.
    Jul 28, 2012 12:10 AM   in reply to tonymuffin
    There is another topic open with a similar problem; see http://forums.adobe.com/message/4584448#4584448
    Can you try what Chris Campbell suggested in his last post?
