I have a document with over 100 layers in it ...which is pretty normal for what we do and Illustrator in CS6 has a big issue with the layer palette .....as you scroll down the palette the layer names disappear ...as you run the mouse over the layers they re-appear and then disappear again ...this issue makes the software useless as I can't see the layers .....this happens on all the documents I've been working on ....anybody getting the same thing and anybody go any ideas of how to fix this or is it Adobe's issue?
Good that you have given all this inforamtion aboiut your system and stuff like that but if you wnt to vent it is important you state so and if you wish help you have to give us enough info so we can respond intelligently and make suggestions.
But off hand I will repeat what I repeated about 100 times in the lat two months.
Do you have plugins, have you loaded new fonts, free fonts, have you trashed your preferences, have you conflicting software installed, did you update any software recently have you upgraded non Adobe software lately and have you repaired your permissions.
And the most important question is why are you using software that is unuseable?
...I should add that I was not venting about Adobe ...meerly pointing out that I can't use it if I can't see the layers ....I've been using Illustrator since 1989 and I have always been a fan ...a helpful approach would be to make suggestions without the underlying patronising tone ..I always find people respond better to that
We are having the same layer panel problems in Illustrator CS6 on two systems in our office. Both are brand new Macs running OS X 10.7.4. I have tried repairing user permissions, changing Layer Panel options, resizing Layer Panel, etc.
Layer thumbnails and names dissapear. Layer tool icons (new layer, delete layer, etc.) dissappear. Sometimes they reappear when moused over.
Really frustrating. There must be a solution to this.
Dis you read what I wrote in Post #1
Now you know why I also wrote that I have rerpeated this a hundred times before.
all you have to do is read iut then follow up on it and you will solve your problem.
I say you have conflicting software install in some form or the other it could be a plug in and update or third party software. Do what you have to do and you will not only solve your problem but you will also find the source of the problem.
In the last two months situation where to the user it appeared to be a bug it has turned out to be conflicting software at least 6 times and this will be the seventh time.
You know what you installed or updated we do not know.
I rrun the same system you have and it does not happen here.
Really, Wade, your condescending tone is unnecessary. You should ask yourself if you come to this forum to actually be helpful or to belittle others and feel superior.
But just to humor you...
I have already trashed my preferences, repaired permissions and updated all Adobe software. There has been no new software or fonts installed since installing CS6. The only plug-in used is Extensis Sutcase Fusion 4 Font Auto Activation and I have uninstalled that with no effect on the problem.
We have four systems running all of the same software and os. Two of them have this problem and two of them don't.
Obviously, this is not an isolated case. I'm looking for someone who has had this problem and fixed it or would have a more helpful suggestion.
Thanks.
I was being condensending you gave no information abou your system how is anyone to know if you are serious or if you are just ranting.
To point out what i mean after several dayus you are still asking trhe same question has anyone else experience this problem and has the solution. I gave you the best advise it is a conflict as simple as that, you do not like the answer I can't do anything about your reaction.
I am giving you sound advice from expereince dealing with these matters and not to brag I have help a lot of people overcome their own issues so they can say hey I was wrong and thank me.
Not all of them thank me and when you find out that i am correct nbeither will you and I know that from experience as well.
Since you do not want my help fine I hope you work it out.
I don't spend a lot of time in Illustrator, and I'm a windows useres, but humor me for a moment. The kind of problem you describe is very often caused by corrupt prefs, and Suitcase is very often associated with odd behavior over in InDesign where I am active.
Did you really remove the Suitcase plugin, or just deactivate it? Deactivation may not be sufficient. And did you also trash the prefs again after removing the plugin?
Do you have the same problem if you create a new user account and use that?
Thanks Peter, I know that Suticase can be buggy. I've completely removed the plug-in and trashed the preferences again after removing. Problem still exists.
I haven't tried a new user account yet, but, if I have time, I'll try to do that and do a fresh install of Illustrator.
I understand that perfectly. What you've established, though is that the user account is corrupt in some way and it isn't abug in the program itself.
Obviously trashing the prfs was not enough by itself. Ove in ID John Hawkinson has made a list of additional files on the Mac to trash when pregs are not enough (http://forums.adobe.com/message/4315274) and I'b bet there are similar files for Illy. You might want to try killing those next.
Thanks Peter. The info in that thread looked promising, but...
I trashed the following files:
~/Library/Application Support/Adobe/Adobe Illustrator CS6
~/Library/Caches/com.adobe.Illustrator
~/Library/Preferences/Adobe Illustrator CS6 Settings
~/Library/Preferences/com.adobe.Illustrator.plist
~/Library/Preferences/com.adobe.Illustrator.plist.lockfile
~/Library/Saved Application State/com.adobe.Illustrator.savedState
Restarted.
No luck. Problem still exists.
I can't help you but there are several users contributing to this thred tht should know how to guide you to replacing the file that Lion is preventing you from replacing.
It's a fairly simple procedure you can do a search if you want on how to do this. But as I say I can't directly help you.
Replacing the user library directory isn't a viable solution anyway. That would just hose all of my preferences for everything else on my system. I might as well start from scratch with a new user and I've already stated that that is not a possibility. We've already established that it is something within my user account that is causing this glitch. The question is, what?
In leu of creating a new user account, you could restore from a solid backup if you have one.
Other than that option, I don't know what else to tell you other than to create a new user account and use Apple's migration Assistant to move as much as possible tot eh new user account.
Trying to find a problem deep in a user account is a fool's errand in my experience. Start over and deal with it, you'll lose less time (and sleep).
I was suggesting, though perhaps not clearly, that you replace only the Illustrator section, since that isn't working anyway (and you might be able to limit it to just CS6). As you must have figured out by now, it isn't easy to determine just which file (or files) are causing the problem. I think if anyone knew, they'd have mentioned it.
It would be easier just to live with the problem and not use template layers until the final save of my projects than to try to create a new user account. I'm not willing to nuke all of my preferences to fix it.
I just wanted to keep this thread visible since there are others who are having this problem. Maybe someone else will have better luck pinpointing the cause.
I didn't realize Crisper was not the OP inn that ca se you log inn as the root to replace the file. But is risky if make a mistake.
Also be alert to trashing the com.adobe.Illustrator.plist alongwith theh setting fholder and cleaning the personal cache and font cache files it looks to me to be a corrupt cache file.
I will post the location of those files later tonight.
colling_s wrote:
Look like you have corrupted fonts.Validate fonts "Tahoma" on Win and "LucidaGrande" on Mac.
LucidaGrande isn't on my system (Mac). I even went back to my install disk and reinstalled the fonts and that wasn't one of them.
I agree that it is probably a font issue, because when you make a layer a template, the layer name in the palette switches to italic and that's what's not showing up (although it also makes the thumbnails and tool icons in the palette disappear).
Anyone know what font that is?
culverbd wrote:
On the first layer with a missing name double click on the thumbnail. In the layer options make sure "print" is checked. This should make all the layers visable again.
Well, yes, because by doing that, you are turning off the template layer. That doesn't stop them from disappearing when you make a template layer.
That may be your issue entirely.
Lucida Grande is the primary font the Mac OS uses to draw windows. All Mac OSX versions require that font.
System/Library/Fonts... if it's not there, you've got issues.
