Help me with a problem
Jul 27, 2012 9:03 AM
Tags: #after #effects #artifacts #bit #avid #16 #compositing
I am editing a short film in avid media composer 6. I complete the edit and export an aaf. I import the aaf in after effects with automatic duck pro. I change the bit depth to 16 bit and suddenly my footage gets introduced to artifacts. They are just pink and blue specs which are all around on the image. They are mostly on highlights but are also showing up in mids and shadows. They are not in every shot but in most of them. The footage is from 5d mark2  which is imported in avid as DNxHD 115. I want to do the compositing and export a 16 bit tiff sequence for grading in resolve. Why are the artifacts showing and how to remove or avoid them. Please help me. They go when i switch back to 8 bit but I have to work in 16 bit. Please help.
    Jul 28, 2012 8:48 AM   in reply to sharry0048
    What version of AE? What OS? Are you using Open GL for rendering? What happens when you go to 32 bit?
    I wish I knew more about Avid Codecs. I'd be willing to bet that the problem started with the conversion to the Avid codec you're using. I'd try importing the original footage from Canon for the example and see what that looks in AE.
    Jul 29, 2012 2:17 AM   in reply to sharry0048
    Turn off OpenGL rendering.
