Disappearing audio problem in CS6
Jul 29, 2012 7:08 AM
This morning I started editing a project which consists of MXF files from my Canon XF100 camera, for which I used the correct sequence preset. The problem I'm having is that while playing the timeline a clip plays fine, but when it starts a new clip there's no audio, even though there is a stereo audio track, and there are waveforms in that track, however, the audio meters show nothing, as if the file had no audio. I have to close Premiere and reopen it, and then the clip plays fine. But then it happens again with some other clips down the timeline. It's not a particular clip that is causing the problem, it's more like random clips, and it happens with one or two clips, and the clip after that plays fine. Closing and restarting Premiere always fixes a particular clip, but it's getting really annoying to do that over and over.
Anyone else having this problem?
    Jul 29, 2012 7:29 AM   in reply to Sebasvideo
    Not here.
    Jul 29, 2012 10:19 AM   in reply to Sebasvideo
    Let's get this one out of the way first:
    When you Imported the other files, did you allow PrPro to completely Conform and Index those files, before you began editing them? This ARTICLE goes into more detail on Conforming and Indexing Imported files.
    Good luck,
    Hunt
    Jul 29, 2012 10:27 AM   in reply to Bill Hunt
    I have several times mistakenly started to edit before PPRO had finished, but again, it might not be the case here.
    Ulf
    Jul 29, 2012 10:32 AM   in reply to UlfLaursen
    Yes. That is a common cause of similar behavior - though not always, but worth removing from the table early - just in case.
    Hunt
