Noel Carboni 23,455 posts
Dec 23, 2006
Should I Go For 24 GB or 32 GB RAM?
Jul 29, 2012 1:45 PM
Over the past few weeks I've been having a computer problem.  Several times my system has halted on an unrecoverable RAM error (I have ECC RAM).  Specifically, in my ca. 2008 Dell Precision T5400 system I currently have 8 x 2 GB FBDIMMs, one of which is apparently failing.  In fact, the BIOS has pinpointed the fault to a pair - DIMMs 5 or 6.
I've done the basic maintenance, cleaning dust, making sure temperatures are good, reseating everything.  I suspect it's just a module going bad.  It happens.
The Dell steps its performance up to quad channel RAM access when it senses matched sets of 4 DIMMs, and I always regard failures as significant opportunities for improvement, so I'm considering buying either four or eight 4 GB DIMMs to replace the (smaller) faulting modules and some nearby.   If I buy four (swapping out four 2 GB modules) I'll end up with 24 GB of RAM.  If I buy eight I'll end up with 32 GB of RAM.  Of course, I could just replace the pair of 2 GB DIMMs that has been identified as faulty.
At this point I really don't see problems working on documents of any size with "just" 16 GB of RAM (keep in mind my scratch files are on a fast SSD array), so I could just get a pair of 2 GB DIMMs (super cheap).  However, the extra RAM will only improve Photoshop's performance...
So...
Should I do a minimum cost replacement with no increase in resultant RAM size, get a set of four 4 GB DIMMs and increase to 24 GB, or get a set of 8 DIMMs and move up to 32 GB total?   Basically the cost is 16 GB - $35, 24 GB - $330, or 32 GB -$660.
  • On the one hand, I like the "more RAM is better" school of thinking.
  • On the other, putting more money into my current system just means I haven't saved as much as quickly toward a powerful new one.
What would you suggest?
-Noel
    Jul 29, 2012 2:34 PM   in reply to Noel Carboni
    You spent thousands of dollars on SSDs and you have to ask?
  • JJMack
    Jan 9, 2006
    Jul 29, 2012 2:48 PM   in reply to Noel Carboni
    ECC Ram that cheep back in the days you remember the cost. If you got the cash the 64bit OS can utilize the RAM these days.
    Jul 29, 2012 3:04 PM   in reply to Noel Carboni
    Yes.
    Jul 29, 2012 5:12 PM   in reply to Noel Carboni
    I have not seen CS 4 or 6 use more then 12 Gb max. I believe anything more is overkill?
