Tesla card in Maximus not being used
Jul 29, 2012 2:22 PM
Tags: #pro #nvidia #premiere #cs6
I spent a few thousand dollars buying a Quadro 6000 and a Tesla M2090, but the later inever gets used at any time by Premiere CS6. I tested the usage with the command below and the GPU and memory is always zero, when playing back, when exporting, etc. The card is simply ignored.
Is there something I am missing? I am exporting a 45 minute video for Youtube only with acceleted effects and it takes about 40 minute to generate the file. Sould it not take much less time?
Philip
C:\Users\Administrator>nvidia-smi -i 0 -q -d MEMORY,UTILIZATION,POWER,CLOCK,COMPUTE
==============NVSMI LOG==============
Timestamp                       : Sun Jul 29 17:12:42 2012
Driver Version                  : 297.03
Attached GPUs                   : 2
GPU 0000:05:00.0
    Memory Usage
        Total                   : 5375 MB
        Used                    : 9 MB
        Free                    : 5366 MB
    Compute Mode                : Default
    Utilization
        Gpu                     : 0 %
        Memory                  : 0 %
    Power Readings
        Power Management        : N/A
        Power Draw              : N/A
        Power Limit             : N/A
    Clocks
        Graphics                : 50 MHz
        SM                      : 101 MHz
        Memory                  : 135 MHz
    Max Clocks
        Graphics                : 650 MHz
        SM                      : 1301 MHz
        Memory                  : 1848 MHz
my configuration:
C:\Users\Administrator>nvidia-smi -q
Timestamp                       : Sun Jul 29 17:18:05 2012
Attached GPUs                   : 2
GPU 0000:05:00.0
    Product Name                : Tesla M2090
    Display Mode                : Disabled
    Persistence Mode            : N/A
    Driver Model
        Current                 : TCC
        Pending                 : TCC
    Serial Number               : 1.0203E+12
    GPU UUID                    : GPU-fde0f3fc-6d39-30fe-d1c4-274c8d289af0
    VBIOS Version               : 70.10.4E.00.00
    Inforom Version
        OEM Object              : 1.0
        ECC Object              : 2.0
        Power Management Object : 3.1
    PCI
        Bus                     : 0x05
        Device                  : 0x00
        Domain                  : 0x0000
        Device Id               : 0x109110DE
        Bus Id                  : 0000:05:00.0
        Sub System Id           : 0x088710DE
        GPU Link Info
            PCIe Generation
                Max             : 2
                Current         : 1
            Link Width
                Max             : 16x
                Current         : 16x
    Fan Speed                   : N/A
    Performance State           : P12
    Memory Usage
        Total                   : 5375 MB
        Used                    : 9 MB
        Free                    : 5366 MB
    Utilization
        Gpu                     : 0 %
        Memory                  : 0 %
    Ecc Mode
        Current                 : Enabled
        Pending                 : Enabled
    ECC Errors
        Volatile
            Single Bit
                Device Memory   : 0
                Register File   : 0
                L1 Cache        : 0
                L2 Cache        : 0
                Total           : 0
            Double Bit
                Device Memory   : 0
                Register File   : 0
                L1 Cache        : 0
                L2 Cache        : 0
                Total           : 0
        Aggregate
            Single Bit
                Device Memory   : 0
                Register File   : 0
                L1 Cache        : 0
                L2 Cache        : 0
                Total           : 0
            Double Bit
                Device Memory   : 0
                Register File   : 0
                L1 Cache        : 0
                L2 Cache        : 0
                Total           : 0
    Temperature
        Gpu                     : N/A
    Power Readings
        Power Draw              : N/A
        Power Limit             : N/A
    Clocks
        Graphics                : 50 MHz
        SM                      : 101 MHz
        Memory                  : 135 MHz
    Max Clocks
        Graphics                : 650 MHz
        SM                      : 1301 MHz
        Memory                  : 1848 MHz
    Compute Processes           : None
GPU 0000:03:00.0
    Product Name                : Quadro 6000
    Display Mode                : Enabled
    Driver Model
        Current                 : WDDM
        Pending                 : WDDM
    Serial Number               : N/A
    GPU UUID                    : GPU-8ab57ebc-584d-5d9d-330a-c689df499b66
    VBIOS Version               : 70.00.57.00.03
    Inforom Version
        OEM Object              : N/A
        ECC Object              : 1.0
        Power Management Object : N/A
    PCI
        Bus                     : 0x03
        Device                  : 0x00
        Domain                  : 0x0000
        Device Id               : 0x06D810DE
        Bus Id                  : 0000:03:00.0
        Sub System Id           : 0x076F103C
        GPU Link Info
            PCIe Generation
                Max             : 2
                Current         : 2
            Link Width
                Max             : 16x
                Current         : 8x
    Fan Speed                   : 35 %
    Performance State           : P0
    Memory Usage
        Total                   : 3071 MB
        Used                    : 3041 MB
        Free                    : 29 MB
    Utilization
        Gpu                     : 0 %
        Memory                  : 0 %
    Ecc Mode
        Current                 : Disabled
        Pending                 : Disabled
    ECC Errors
        Volatile
            Single Bit
                Device Memory   : N/A
                Register File   : N/A
                L1 Cache        : N/A
                L2 Cache        : N/A
                Total           : N/A
            Double Bit
                Device Memory   : N/A
                Register File   : N/A
                L1 Cache        : N/A
                L2 Cache        : N/A
                Total           : N/A
        Aggregate
            Single Bit
                Device Memory   : N/A
                Register File   : N/A
                L1 Cache        : N/A
                L2 Cache        : N/A
                Total           : N/A
            Double Bit
                Device Memory   : N/A
                Register File   : N/A
                L1 Cache        : N/A
                L2 Cache        : N/A
                Total           : N/A
    Temperature
        Gpu                     : 84 C
    Power Readings
        Power Draw              : N/A
        Power Limit             : N/A
    Clocks
        Graphics                : 573 MHz
        SM                      : 1147 MHz
        Memory                  : 1494 MHz
    Max Clocks
        Graphics                : 573 MHz
        SM                      : 1147 MHz
        Memory                  : 1494 MHz
    Compute Processes
        Process ID              : 4348
            Name                : C:\Program Files\Adobe\Adobe Premiere Pro CS6\Adobe Premiere Pro.exe
            Used GPU Memory     : Not available in WDDM driver model
    Jul 29, 2012 3:17 PM   in reply to philip_38
    Do this.
    Turn off hardware acceleration in PP and export again.  If it takes longer, then all is well, hardware acceleration is working properly.  If it still takes the same 40 minutes, then something is wrong.
    Jul 29, 2012 3:33 PM   in reply to philip_38
    The test will determine if hardware acceleration is actually in use.  I don't trust metering tools to tell the whole story, as I've seen some that suggest no acceleration is occurring when I know for a fact it is.
    Jul 29, 2012 3:51 PM   in reply to philip_38
    Return it and get a refund. The Tesla M is for servers only and requires Windows Server 2008 as an OS. It is not supported with Windows 7 and will not work even with the 'hack' applied.
    The only Tesla that will work is the C2075 and for the meager amount of an additional € 2300 (that is in addition to the Quadro card) it will give you ZERO, NIL performance improvement over a € 400 GTX card. And that is only in single CPU systems, because Tesla will not work in dual CPU systems, if HP is to be believed.
    Results of Maximus solutions with Quadro 6000 + Tesla C2075 (for only € 6000) are no better than a single GTX 560 Ti for around € 240. The only situation where these €€€ may be well spent is if you need 10 bit output for your € 2000+ each monitors.
    Transcoding is purely a CPU matter. There is no acceleration with CUDA enabled cards, apart from scaling, blending and blurring. All the rest is only CPU dependent.
    Jul 29, 2012 9:41 PM   in reply to philip_38
    I dont think you will have surprised anyone here by your findings.
    How did you dig yourself such a deep and expensive hole in the first place.?  I am assuming bad advice from an equipment retailer.
    Fact its a hobby is even more startling to me!
    BTW - I hope you are not pointing the finger at Adobe or Nvidia for this?
    Adobe / Nvidia put up the specs and you ran off with the ball seemingly without any foundation or research.
    Jul 29, 2012 10:10 PM   in reply to philip_38
    If I can suggest a GTX 670 card (with 4GBs onboard)   plus the GTX285 may easily satisfy you once you lose the rest of the "stuff"
    Throw the two in together ...using the 285 for GUI (monitoring) and the 670 in for 1334 core  CUDA power (no monitors).
    IMHO : Best Adobe support will be found in this forum - including the Hardware Forum.
    We have Users plus the Adobe lead guys playing around here.
    These guys listen and contribute.
    Adobe Support is not highly regarded here at a solution level.
