ccapling
PDF has boxes during on screen view, but prints fine
Jul 28, 2012 6:23 PM
Tags: #acrobat
When viewing a PDF, some areas are blacked out, such as cells on a table. However, when I print them, they look fine. I have made sure "Show large images" is checked, as suggested from other forums.
    Jul 29, 2012 5:23 PM   in reply to ccapling
    I suspect that the fonts are not embedded OR you have use local fonts turned on. Check both.
    Jul 30, 2012 6:38 AM   in reply to ccapling
    I am not sure, but it may be that you are looking at it to different versions of the products. What versions of Acrobat and Reader are being used. Sometimes, transparencies have some display issues, but I really do not know how to handle them.
    Jul 30, 2012 10:59 AM   in reply to ccapling
    I think it is a graphic transparency issue, but I need to let the graphics folks address that one.
    Jul 30, 2012 5:41 PM   in reply to ccapling
    Acrobat 9 and Reader X are not compatible! It is an unsupported combination. Only Acrobat X and Reader X are compatible. So the issue could stem from that. The issue could also stem from a video driver problem. See if you can turn off any video driver acceleration.
