CQ5
Re-size an image in using the Image class?
Jul 23, 2012 6:16 PM
Is there a way to resize an image using the com.day.cq.wcm.foundation.Image class?  I wanted to extend the foundation image componet and have it resize to a specific height and width.  Is there a way to change the size of the image before you call image.draw(out) ?
    Jul 23, 2012 6:34 PM   in reply to stewa52
    Try using ImageHelper to get a resized layer & then apply
    http://dev.day.com/docs/en/cq/current/javadoc/com/day/cq/commons/Image Helper.html
    Jul 25, 2012 12:30 AM   in reply to stewa52
    You also don't want to insert you resizing efforts prior to calling the image.draw method. The draw method doesn't actually render the image,  it draws the HTML img tag that your components print out. If you were to use the ImageHelper to get the layer and resize it that would not actually change the size of the image.
    Now that img tag will contain a URL to the image, and that URL will generally look something like this (unless you have customized your image components):
    /path/to/your/page/_jcr_content/par/textimage/image.img.jpg/1323947520 848.jpg
    This URL is going to trigger a script or servlet that will be responsible for rendering the image. In the example above because the textimage component extends the parbase component and because URL includes the img selector it will end up triggering the servlet at /libs/foundation/components/parbase/img.GET.java. If you go into CRXDE Lite you can go to this file and look at the source code of this servlet and see an example of how it uses the layer to resize the image if that author edited the image in the smart image widget.
    You can also see example of servlets that resize and image ot specific preset sizes (as you want to do) you can look at /apps/geometrixx-outdoors/components/product/image/thumbnail.GET.java and /apps/geometrixx-outdoors/components/product/image/nav.GET.java.
    So what you would want to do is something like this:
    1. Create your own component at /apps/mysite/components/foo
    2. Create a servlet at /apps/mysite/components/foo/bar.GET.java - put your logic to resize the image here based on some of the examples
    3. Create your component JSP at /apps/mysite/components/foo/foo.jsp
    4. Create your component's dialog and in this dialog include a smart image widget - make sure you store your image on component node, not a sub-node. If you store your image on a sub-node you need to make sure the sub-node includes the same resource type as your main node).
    5. In your component JSP when you create your foundation Image object make sure to image.setSelector("bar") before you call image.draw()
    That should result in an image URL that looks like /path/to/your/page/_jcr_content/par/textimage/image.bar.jpg/132394752 0848.jpg
    Those steps aren't tested - so I may have missed something or mistyped something, but it should point you in the right direction.
    Jul 29, 2012 7:01 PM   in reply to orotas
    Good info. Thanks for right direction.
    May 20, 2013 6:44 AM   in reply to Sham HC
    There is a default servlet available which does resizing, you can find this here
    /libs/foundation/src/impl/src/main/java/com/day/cq/wcm/foundation/prof ile/impl/ProfileImages.java
    This works fine if you use default version and call image like this
    <img  src="/content/dam/geometrixx/portraits/scott_reynolds.jpg.prof.thumbn ail.jpg">
    I have created another thread for extension of this servlet, please view the following thread
    http://forums.adobe.com/thread/1215666
