Target adjustment tool Menu does not appear
Jul 30, 2012 12:35 AM
Tags: #target_adjustment_tool #acr_7.1
Hello
I use ACR 7.1 and I have a problem with this tool : when I clic on this icon on the top tools bar I have no menu I should get a menu with parametric curves hue saturation luminance but nothing. Of course I could use the HSL part on the right interface but I would like to know why my ACR behaviour is not has it should be.Thanks
    Jul 30, 2012 12:38 AM   in reply to tartempion77
    By default, the TAT defaults to Parametric Curves unless you are either in the HSL panel or the Grayscale panel in which it then works with those parameters...if you want HSL or Grayscale, you need to click on that panel. Otherwise TAT does only Parametric Curves...that's as designed.
    Jul 30, 2012 2:27 AM   in reply to tartempion77
    tartempion77 wrote:
    Thanks for answer but it is not what i meant: what I said is I have no dropdown menu when I clic on Target adjustment tool icon
    Uh huh...didn't I mention the fact that by default when you click on TAT you get Parametric Curves by defatult (and no, it doesn't change to the the panel, by design). If you want HSL or Grayscale you need to click on the panel to switch from curves...
    You would be better off learning the actual behavior...
