Hello everyone !
I'm using Flash Builder 4.6 and recently I wanted to build something in flash. I have all versions of Flash(standalone, standalone debugger, plugins).
When I try to compile my project it gets stuck at 57% and than displays an error saying that I should ensure for in-browser applications I'm using debugger version, and for network debugging on a mobile device, etc(I'm not using an external device).
I can't debug/run my application from html file, neither as standalone swf. But interesting enough, when I open the swf file from bin-debug it actually displays exactly what I coded.
Three days have passed while I'm trying to fix this problem. I tried every possible solution searching in internet and I had not luck at all.
I hope someone can give me the right answer here.
p.s
I need to clarify that I haven't been using flash for months (It worked before) and during this time I have set up an Apache server on my pc for php coding. I don't know if this is related.
Yeah, thanks for your suggestion I did it many times in fact.
I found a solution some hours ago.
It seems it was an odd problem from Flash Builder and it displayed an error which was not related in anyway with the problem.
This is a visualization of my problem ...if this happende to you before how did you fix it ? (Maybe I haven't tried everything)
No real clue here, but since you did install software since it last worked, I'd suggest uninstalling/reinstalling builder.
