Entering/Saving Text Data with AS3
Jul 29, 2012 9:57 PM
Tags: #flash #data #text #as3 #cs5.5 #xml #actionscript3 #saving_data
I'm creating a desktop application for the beginning of the school year and I need to be able to have people manually fill in data in text fields (input text fields), primarily just names - and when they open the application they need that data to still be there.  I also want them to be able to edit and delete the data that they enter, possibly even using some kind of "save" button, just spitballin'.  What would be the best/easiest way to accomplish this?  Any ideas?
  • kglad
    Jul 21, 2002
    Jul 29, 2012 11:01 PM   in reply to Claunchster
    use the SharedObject.getLocal() static method.  you don't have to worry about reading and writing files.
    Jul 30, 2012 4:17 AM   in reply to Claunchster
    You can use SharedObject as kglad suggested, or you can also use AIR's File/FileStream to write to say a csv file, which can be useful if you want to graph data, etc. It's very easy actually - here's a nice 10 line example:
    http://www.numbmedia.com/blog/?p=159
  • kglad
    Jul 21, 2002
    Jul 30, 2012 10:26 AM   in reply to Claunchster
    you're making this a lot more complicated for no apparent reason.
    if you need to create a human readable file, it makes sense to use the file class and in that case, and with the code you're now using you need to use readUTFBytes().  are you?
    and, if you don't need to use a human readable file, use the sharedobject:
    var mySaveNewDataArray:Array = new Array("txtName1","txtName2", "txtName3", "txtName4", "txtName5", "txtName6", "txtName7", "txtName8", "txtName9", "txtName10");
    var so:SharedObject=SharedObject.getLocal("dataSO");
    if(so.data){
    for(var s:String in so.data){  // this reads the data
    trace(s,so.data[s]);
    so.data.dataA=mySaveNewDataArray.concat();  // this writes the data
    so.flush()
  • kglad
    Jul 21, 2002
    Jul 30, 2012 11:00 PM   in reply to Claunchster
    if your textfield is your_tf, use:
    var tfS:String = "";
    if(so.data){
    tfS+=so.data[s].toString();
    your_tf.text = tfS;
    so.flush()
  • kglad
    Jul 21, 2002
    Aug 1, 2012 12:29 AM   in reply to Claunchster
    use:
    var tfA:Array = new Array(txtName1,txtName2, txtName3, txtName4, txtName5, txtName6, txtName7, txtName8, txtName9, txtName10);  // no quotes
    if(so.data){
    for(var i:int=0;i<tfA.length;i++){
    tfA[i].text=so.data["tf"_text"+i];
    // when your textfields are ready to have their text saved, call saveTextF:
    function saveTextF():void{
    for(i=0;i<tfA.length;i++){
    so.data["tf_text_"+i]=tfA[i].text;
    so.flush();
  • kglad
    Jul 21, 2002
    Aug 1, 2012 7:56 PM   in reply to kglad
    use:
    for (var i:int=0; i<tfA.length; i++) {
        if (so.data["tf_text_" + i]) {
            tfA[i].text = so.data["tf_text_" + i];
    so.flush();
  • kglad
    Jul 21, 2002
    Aug 2, 2012 6:46 PM   in reply to Claunchster
    you're welcome.
