Dragging a mask to the trash applies it instead of deleting it
Jul 30, 2012 10:27 AM
Tags: #cs6 #masks
When I drag a layer mask to the trash, it applies the mask instead of deleting it, removing all masked out pixels. I don't believe this was the case before CS6. Is there a way to adjust this setting and make it simply delete the mask?
Right-clicking still gives me the option to delete the mask properly.
    Jul 30, 2012 10:35 AM   in reply to gmrmstudio
    Hi gmrmstudio
    When you drag the mask to the trash can, you should be receiving a pop up window saying "Apply mask to layer before removing?". The options are apply, cancel, and delete.
    Jul 30, 2012 10:41 AM   in reply to gmrmstudio
    You should see the following dialogue unless you've previously ticked "Don't show again". I guess you ticked that when recently applying a mask.
    I don't know how to make the dialogue reappear, except by resetting the entire Photoshop preferences.
    Edit: at bottom of Preferences > General is "Reset all warning dialogs". Maybe that'll bring back the dialogue.
    Jul 30, 2012 10:39 AM   in reply to gmrmstudio
    If you previously lclicked "Don't show again" when recently applying a mask like conroy2009 said, you can reset your preferences and the dialogue window should show up again.
    Jul 30, 2012 10:41 AM   in reply to Sharon Huang
    At bottom of Preferences > General is "Reset all warning dialogs". Maybe that'll bring back the dialogue without resetting all preferences.
    Jul 30, 2012 7:29 PM   in reply to gmrmstudio
    You can also press the Alt (option) key while dragging the layer mask to the trash can to bypass the dialog and delete the mask without apply.
