Replacing instead of conforming
Jul 30, 2012 5:13 AM
First a little explanation. I have a very big crazy project, where more than 124 hours of DVD material is editet into a few minutes of fast cuts. I am using the original VOB files and separate wav files to edit. Because of the growing size of the project and my disk slipping full with *.cfa files that are almost twice the size of the VOB files, I checked "Save media files next to originals when possible" and let Premiere re-conform everything. Although not advised, this saved me internal disk space (as the project files are on an external disk). I find it weird anyway that project related files are stored in some temp folder by default. Not very incterchange-friendly.
I did all this in CS5. Now I've opened it in CS6, and it's started to conform all the material again. So I guess I would need to delete all the *.cfa and *.pek files to ensure no redundant files are on the disk.
This made me think about using the conformed material as the actual file, so I wouldn't need the VOB files anymore, and premiere would never need to conform it again. This is what Premiere seems to do anyway. Is there any way to do this? Or would I need to batch process all the files in Predule and batch replace the clips in Premiere, if possible?
    Jul 30, 2012 9:18 AM   in reply to Malloot
    There's no way to do that.
    Jul 30, 2012 9:20 AM   in reply to Malloot
    The CFA & PEK files are what PrPro actually uses to do the editing. They are created from the original Audio files, and are stored, where you direct PrPro to do so. If they are removed, then PrPro will regenerate them, when the Project is Opened. If you are moving them about, you are probably better off just changing the location in Edit>Preferences, and then Deleting them. Clean the Media Cache. When you Open the Project, sit back, have a cup of coffee, and just let PrPro regenerate them, where you have relocated them.
    This ARTICLE will give you more info on the CFA & PEK files.
    Also, it might be helpful to know the full specs. of your I/O sub-system, i.e. your HDD's, their size, speed, free-space, controller type and how you have them allocated.
    Good luck,
    Hunt
    Jul 30, 2012 11:20 AM   in reply to Malloot
    At a certain point you'd need a separate drive just for temporary CFA and PEK files.
    That is part of the ideal setup, yes.
    Jul 30, 2012 12:34 PM   in reply to Jim Simon
    Is there a way to NOT import audio from VOB files?
    Yes, you can rip the discrete Audio and Video Streams from the MPEG-2 contained in the VOB. There are many ripping software options, though I do not know which ones might offer the option of separate, demuxed Streams. There is a list of some ripping software in this Encore FAQ Entry. I am sure that there are many, many more, and also demuxing utilities.
    Also, PrPro is not very "secretive" about the Conforming and Indexing process - there is a progress bar that displays in the GUI, informing that the operation is in progress, and giving a graphical progress representation.
    Good luck,
    Hunt
