Photoshop on OSX 10.8/ML throws "strtable error" on open dialog
Jul 30, 2012 11:06 AM
Tags: #photoshop #issue #cs6 #strtable
Upgrading to ML with the newest CS6 (creative cloud) and in the open dialog, clicking on PSDs gives a generic "strtable error". I can still open the files. Any ideas what this may be?Screen Shot 2012-07-30 at 2.04.21 PM.png
  • Noel Carboni
    Dec 23, 2006
    Jul 30, 2012 11:52 AM   in reply to boboroshi
    Check carefully to see that the text that you have defined in the design is editable.  There's a pretty bad bug being worked on by Adobe in which the various text in the document gets shuffled.  That came to mind because "str" could mean "string", which is programmerese for text.
    -Noel
    Jul 30, 2012 12:01 PM   in reply to boboroshi
    Yep, I'm having the same problem.
    Jul 30, 2012 2:25 PM   in reply to klmhicks
    That's not a Photoshop error (wrong icon, not one of our strings).
    I don't even think it's an OS error, but possible some haxie or system utility that you've added to your system.
    Jul 30, 2012 3:19 PM   in reply to boboroshi
    If you've got FontExplorer X Pro installed, try disabling the font requests and re-enabling them.
    I figured it might be something to do with that from the previous replies, and I can't trigger the bug anymore.
    Not necessarily the cause, but it seems to be working OK now
    Nov 22, 2012 5:57 AM   in reply to boboroshi
    In my case it was FontExplorer X Pro.
    Even if you unistalled it, error remains.
    You need to go to Photoshop Plugins folder and delete FontExplorer Plugin
    Nov 30, 2012 12:22 AM   in reply to Sergei Emelianenko
    Thnaks, that was it, had to delete the plugin in Illustrator fodler as well
    Jan 8, 2013 2:30 PM   in reply to kjllkzfdghda64564564
    How does deleting the FontExplorer extension effect your use/operation with FontExplorer & Photoshop (or Illustrator)? I also want to get rid of this bug but need to continue to utilize FontExplorer to manage fonts... Thx
