Linked gif in DIV w/ Flash
Jul 30, 2012 1:14 PM
I have a DIV with a placed Flash instance. Underneath that instance I want a small gif file to contain a link. This setup worked fine when the layout was in tables. Converting to DIVs the link is not recognized (doesn't show as clickable) If I place it anywhere else on the page is works as it should. If I take the Flash instance out of the DIV, it works. So what is causing the link not to work with Flash in the DIV and what can I do to solve the issue?
Thanks.
    Jul 30, 2012 1:20 PM   in reply to jnwbr
    Please post a link to the problem page so we can take a look in our browsers,
    Jul 30, 2012 1:26 PM   in reply to John Waller
    I'm guessing some CSS z-index work may help or maybe some fixed pixel sizes for the divs. You probably have the larger div overlapping the link in one way or another.
    A link would be very beneficial, even to a temporary page.
    Jul 30, 2012 2:13 PM   in reply to jnwbr
    The footer div is overlapping the section5flash div
    It's inheriting a padding-top:100px. If you set the padding-top to something much smaller in the footer css, it should fix it.
    EDIT: OOps, it's stacking the padding-top from the copyright and footer definitions
    Jul 30, 2012 2:46 PM   in reply to jnwbr
    From what I've been able to find applying top or bottom padding/margins wouldn't work because span tags are inline elements (that's what you have your copyright CSS affecting). You would have had to either float the span tag, or give it a display:block before the vertical padding would have appeared.
    Jul 30, 2012 2:55 PM   in reply to jnwbr
    Nah, just use divs for all of your positioning work and you'll be fine..
    Jul 30, 2012 3:11 PM   in reply to Jon Fritz II
    Paragraphs and headings are block level by nature.  I would never recommend using a <span> tag to replace a <p>, <h1>, <h2>, <h3>, etc...
    Headings and paragraphs impart semantic meaning to content.  Span tags impart no such meaning.   Spans are mainly used as hooks for when you need a special style within a line of text.
    Example:
    <p>Some normal text... <span style="font-size: 55px">Some really big text in a span</span> and some more normal text.</p>
    <p>Some normal text... <span style="color:red">Here is some red text in a span</span> and some more normal text.</p>
    Nancy O.
