Mc20piece
Export not exactly 1920x1080
Jul 30, 2012 6:24 PM
Let me start off by saying that I am a total lightroom beginner. I am using publish to HD or sometimes simply right click and export to a JPG with a resize to 1920x1080 and it never comes out that ways. It comes out every time to 1919x1080.
I'm shooting with a Sony ALT-A65V in 16:9 mode. You can see the original, the settings I used and the resulting JPG.
Also, I notied another posting referencing something similar but is there something lightroom does to the photo by default? Even once a photo seems to be rendered in my view it seems to change slightly after a second or two.
    Jul 30, 2012 7:05 PM   in reply to Mc20piece
    That is because the size you are after 1920x1080 is a different ratio from your original - just slightly. So you could set up a crop ratio of 1020x1920 in the Crop tool but tell what you are wanting tod achieve, there may be other options.
    Jul 31, 2012 10:25 AM   in reply to Mc20piece
    I was just exporting for easy display on any of my monitor and our TVs. Should I not shoot in 16:9 and then just crop it myself?
    It doesn't matter what dimensions you shoot at. The problem is that 6000x3376 is not exactly the same ratio as 1920x1080. So, if you want exactly 1920x1080, then as Geoff explained, you MUST crop to that ratio (I believe he had a typographical error, I'm pretty sure he meant to say you must crop to a ratio 1920x1080)
    "Also, I notied another posting referencing something similar but is there something lightroom does to the photo by default? Even once a photo seems to be rendered in my view it seems to change slightly after a second or two."
    Could you be more specific about what you are doing and where in Lightroom are you looking, when you see this?
    Jul 31, 2012 11:30 AM   in reply to Mc20piece
    This is normal. Lightroom first shows you the JPG preview until it can render the RAW photo, which of course looks different.
