Spacebar Shortcut: Hand Tool Showing But Not Working
May 15, 2012 2:44 PM
Tags: #photoshop #bugs #cs6 #spacebar #keyboard_shortcuts #hand_tool #functionality #hand_tool_keyboard_shortcut
Runing the CS6 trial on a Windows 7 Laptop (x64). I was in Photoshop (64), and noticed that when I held down the spacebar to pan the open image, the hand icon would show but the tool will not work. No matter how many times I click and drag, the image stays still. If I select the MANUALLY select the hand tool it works, but the spacebar shortcut key is non-functional. This issue persists across both the 32 & 64 bit versions of Photoshop.
Ideas? Help?
  • Trevor.Dennis
    May 24, 2010
    May 15, 2012 2:53 PM   in reply to TheChexican
    The only time I can think of when the Space bar won't pan, is when the image is zoomed to fit to screen or smaller, but you say things are OK if you select the Hand tool from the Tools panel. So it is getting into one of those unexplained situations where it is time to try resetting Photoshop's Preferences. Restart Photoshop, and immediately hold down Shift Ctrl Alt
    May 15, 2012 5:23 PM   in reply to TheChexican
    For me, the hand doesn't even show (or work) when I hold the spacebar. This is true in Photoshop, Illustrator, and InDesign CS6. I'm on a Mac running 10.7.4. This is very dissapointing as this is probably my most used shortcut.
    May 15, 2012 5:33 PM   in reply to paulburd
    There was a problem aired a year ago about a bug in Trackball mouse and Photoshop.  If memory seerves me corretly (and it does not always) believe it was holding the space bar and trying to move image.
    Would not work on several Window machines..
    If using a track ball try a wired mouse.
    May 15, 2012 6:06 PM   in reply to TheChexican
    This seems to be a problem with the trackpad drivers for Vista and Win7. You can see this behavior on the Desktop: if you click-drag while holding the spacebar, the cursor doesn't move. Using an external USB mouse works fine - in Photoshop too.
    May 15, 2012 8:23 PM   in reply to paulburd
    Strangly, mine spontaniously started working shortly after writing my earlier comment. The only thing I did was close several webpages I had open (in Chrome). I can't imagine open web pages would prevent this functionality... but I can't really explain what happened.
    May 16, 2012 10:39 AM   in reply to TheChexican
    The Chrome (and I guess Firefox) problem was due to the Flash plugin. Once I disabled that, I got my space bar back in CS5.5. But now that I'm in CS6, the shortcut is not working no matter what browsers I close (even all of them). I will look into using a wired mouse but I'd really like to have both working together.
    May 28, 2012 7:00 PM   in reply to KeyStudio
    Hello:    I am using Photoshop CS6 and the spacebar will not function for me either.
    I am creating a circle, duplicate the layer, then i select the subtract front shape ... after this i need to be able to use the spacebar to center my subtracting circle so thatt i end up w/a nice border.
    I closed firefox but that didn't work and so then I restarted my computer w/out opening FF at all and still the spacebar will not work.
    Rather than the hand icon appearing the only thing that changes is that the small black box that shows the height and width adds the x & y demensions.
    Does anyone know if i need to turn something on or off in order to enable the spacebar?
    Thank you for your time : )
    Murph
    Jun 7, 2012 12:40 AM   in reply to TheChexican
    Hi everyone! I had a similiar problem in InDesign CS6 but I managed to solve the problem.
    InDesign CS6
    1) Edit -> Key Shortcuts
    2) Select "Tools" in Product Area drop down menu
    3) Select "Hand Tool"
    4) Click the empty field of "New Shortcut"
    5) Press spacebar and "Space" text automatically appears on this field.
    6) You will be prompted to save default copy, and click Ok
    7) You should be able to see the new entry "Default: Space" on the Current Shortcuts box.
    8) Click "Default: H" and then press "Remove" button.
    9) You are done. It should be working when you press spacebar and the screen moves.
    Hope this helps.
    Cheers,
    Andre
    Jun 7, 2012 12:22 PM   in reply to andrexng12
    Andre, you're a life-saver! Thanks!
    Jul 30, 2012 6:14 PM   in reply to Trevor.Dennis
    Hello guys!
    I have a question too.  The Space bar won't pan when the image is smaller then the screen. Is this a bug or did they removed the feature with CS6?
    Thank you!
  • Noel Carboni
    Dec 23, 2006
    Jul 30, 2012 6:23 PM   in reply to BogdanStetco
    Seems the same as CS5 to me.  Do you have the full screen mode and Application Frame settings the same as when you tried it in Photoshop CS5?
    -Noel
    Jul 30, 2012 6:28 PM   in reply to BogdanStetco
    BogdanStetco wrote:
    Hello guys!
    ... The Space bar won't pan when the image is smaller then the screen ...
    Welcome to the forum!
    The pan works with images smaller than the window in "Full Screen Mode" and "Full Screen Mode With Menu Bar". Press F key to cycle through these modes and "Standard Screen Mode".
    Jul 30, 2012 6:33 PM   in reply to conroy
    @Noel I am in Standard Screen Mode.
    @Conroy Thank! I know that it works in both of full screen modes but I was wondering if it works the same way even in Standard Screen Mode.
    Thank you guys!
    Jul 30, 2012 6:36 PM   in reply to BogdanStetco
    No, not in CS6 or CS5.1 on a Mac. Is there a version that you remember it working in?
    Jul 30, 2012 6:44 PM   in reply to conroy
    If I'm not wrong it was working on CS5, if not definitely was working on CS3. Anyway thank you so much for your help!
    Aug 1, 2012 4:00 PM   in reply to TheChexican
    I just installed Photoshop CS6 on a powerfull new computer (i7-3370K + 16GB) running Windows 7 x64. I have a Wacom Intuos 5 touch installed also. I am really ANGRY about the space bar pan feature which has been one of my favorite functions in CS5. In CS6 it works about half the time! Sometimes the hand tool never shows up when the spacebar is depressed.
    Sometimes the hand tool shows up but there is no panning!!!
    To continue what I want to do with a brush, I have to select the hand tool and use it to pan and then switch back to the brush!
    This really stinks!!!
    Jim
    Aug 2, 2012 8:13 PM   in reply to Trevor.Dennis
    I was having this issue while using my Wacom bamboo tablet.  I found a tip in a forum, to disable all of Windows touchscreen/touchpad features in the control panel and it worked like a charm.
    Jan 29, 2013 8:07 AM   in reply to paulburd
    Thanks paulburd, that fixed my problem. I have Photoshop CS6 on a Mac and my "spacebar" hand feature dissapeared completely. But then, I closed Chrome and it worked fine! I also run CodeKit, and I have this well linked with Chrome so I'm not sure if that was the issue, but closing Chrome totally did it! Thanks!
    Apr 16, 2013 4:59 AM   in reply to bobbylawless83
    Same thing happens to me, sometimes I have to quit Chrome and the spacebar shortcut works again. I can even start up Chrome again and the shortcut continues to work.
    Seems more related to Chrome running a lot of tabs or being open for a long time.
