Hello!
Pardon my ignorance, but I'm jumping into Premiere feet first with little prior experience. I'm working on some digitized Super 8 footage, but everything I have is currently still in negative form. I'm trying to apply a few initial effects to see the footage properly (desaturation and inversion), but I cannot seem to apply effects to Source clips if they are not already in the timeline. As you can probably understand, this makes splicing a film together rather difficult.
I was using a copy of Final Cut Express earlier tonight, and that seemed to communite with the source clips (i.e. apply initial effects) rather well. Does Premiere have the same functionality? This is quite frustrating.
Thanks for the help!
Dave
Thanks for the help! Just to confirm - there is no way to apply effects directly to the source for a preview (in order to mark the in/out points for inserting clips)? That's a real pity...
I tried the method you suggested, though I'm confused - if I'm editing on the timeline, how would using an adjustment layer be different from adding the effects directly to the clip?
There is no way to apply fx to the source clips before you edit them.
One adjustment layer will save you adding the fx to each of the clips individually.
Your first task is to be able to see the clips and some how you managed to get clips in negative? How did that even happen?
Use the trim tools in the timeline will acheive the same thing as marking edit points in the source monitor if not a little slower..
In another lifetime, I worked a lot with S-8, and never saw negative stock in that format. It was only 16mm, and above, that had both negative and positive stock.
Now, and this is just a guess, but I would speculate that FCP is able to apply Effects during the creation of the intermediate files, that it uses.
Since PrPro is Importing the files natively, with no intermediates, there is no place in the workflow for pre-processing Invert, etc.
Hunt
Thanks for the help, everyone! Looks like I'll have to find another way to do this.
In regards to having a negative print - the camera print is negative. It's Super-8 Tri-X developed to a negative instead of a positive. There is no existing positive print, so the negative print was telecined.
I don't know why it wasn't inverted at telecine. I didn't order the conversion, and I haven't talked to the tech who did it. I'll ask the next time I'm by the lab.
Forgive me if I'm not understanding the term perfectly - for "grading," you're talking about the color specifics for the footage? It was B&W film.
Okay, thanks. The output files from the telecine (negative) have a blue cast, so they still need to be desaturated. The contrast is not set properly, but in the vast majority of scenes nothing is clipped.
I think I'll just export all of the files into a positive clip. Is there any easy way to imprint the time codes from Premiere?
You do not want to burn in the Time code.... that will make it unuseable in the edit.
If you export an intermediate from the timeline..there will be timecode in the new clip(s). The TC will match the timeline TC. You can change that if need be. You can also "Post Time code" to the clip(s) later
Ah, now I understand. I used to shoot Tri-X, but then bleached and redeveloped it to a Positive, as lab printing services from S-8 negative (B/W only), was very limited, unlike for 16mm and above.
Thanks for that clarification.
Good luck, and wish that I had more to offer, than what Craig already has.
Hunt
Got it - thanks!
Jim - Okay, I understand now. Reason for not making a positive print was purely financial - more film, more processing, more time.
Bill - I'm working at the local community darkroom, and they have a few chemicals on-hand, including dektol, D-76, fixer, etc. They don't have any bleach available, so it's just easier to process into a negative. Quite welcome for the clarification - thanks for the interest!
Thanks everyone for the help and suggestions! I'll create some intermediate files and go from there.
Dave
Dave,
You are bringing back memories of my darkroom days - stop that! ![]()
I would have to dig deeply into my B/W cine processing documents to pull the bleach formula, and then the redevelopment method. Seems (we ARE talking ~ 40 years ago), that one did a "flash" between the bleach and clearing step, and the redevelopment. Been too long, for me to go off quoting the steps now.
I had not considered that you were shooting B/W, and were stopping at the processing to negative. That was the last thing on my mind, when I read your thread, and Craig's Reply on "negative."
Thanks for the trip down "memory lane." ![]()
Good luck,
Hunt
