lanejd
JS -- XML Question - Can I add attributes using Javascript?
Jul 30, 2012 2:26 PM
Tags: #javascript #xml #attributes
I want to add an attribute to an element tag, but I don't see how to do it programmatically. Is it possible? Also, is there a way to name an element tag dynamically? For example:
The way to add a child element is to either use the appendChild method like this:
XMLObject.appendChild(<childElement/>);
XMLObject.childElement= "something";
or just add it like this:
XMLObject.childElement = "something";
Right? (Side Question: Is there a difference between these two methods?).
What I want to do is to either add a dynamic attribute to a statically named child, or to create a dynamically named child.
I haven't been able to figure this out myself. Any ideas?
    Jul 30, 2012 5:09 PM   in reply to lanejd
    Maybe have a look at Mozilla's E4X tutorial: https://developer.mozilla.org/en/E4X_Tutorial/
    There's no need for eval() here. (There usually isn't.) Use:
    XMLObject.appendChild(<{nameReference}/>);
    To add an attribute, you can just use:
    XMLObject.@new_att = "the value";
    Jeff
    Jul 30, 2012 11:03 PM   in reply to absqua
    XMLObject["@new_att"] = "the value";
    With a slight variation the attribute name can also be specified as string, see above.
    To remove the attribute, delete it.
    delete XMLObject["@new_att"];
    Dirk
