problems with the new motion tween
Jul 31, 2012 1:55 AM
i face issues with the new motion tween especially when the object is under a mask. Has anybody else faced it?
    Jul 31, 2012 1:59 AM   in reply to droidcub
    Could you please tell us more about the issues you are facing? What kind of issues are these? When exactly does the issue surface?
    Please have a look at this FAQ and provide more details as outlined in this FAQ to help investigate your issue further.
    Suhas Yogin
    Jul 31, 2012 2:29 AM   in reply to droidcub
    I think its related to FPS settings in your application.  Please change your FPS settings to 24 or 30 FPS and export the file swf.
    This issue is not resolved then change the duration in timeline and export swf as same FPS.
    Please let me know if its works fine.
    Jul 31, 2012 5:01 AM   in reply to droidcub
    Hello,
    Could you please tell us which version of Flash Professional you are using?
    Also, how are you playing your animation on the timeline? As in, are you scrubbing the playhead (drag it left to right) or by clicking the Play button?
    Also, did you try and test your SWF in a browser (Control > Test Movie > in Flash Professional)  and/or within the Flash Professional SWF renderer? Do you observe the jerky behavior then?
    Suhas Yogin
    Oct 16, 2012 4:19 AM   in reply to Suhas Yogin
    I have been able to reproduce this bug in Adobe Flash Professional CS5.5. If your mask is a shape tween that lasts 12 frames, and the masked layer contains a movie clip of a motion tween that lasts 48 frames, the movie clip will be cut off and repeat after only 12 frames instead of playing the 48 frames. Is there a workaround for this?
