Hi all,
I have made an Edge html animation published as .oam file and put in a iPad 2 resolution Indesign Document. Everything works fine.
When I create an Edge document, publish as .oam and put in a iPad 3 resolution indesign document the result is not good. All is out of zoom.
The same occurs with an html file from another app than Edge.
Anyone have the same problem?
Hi Anselm, I have done some screen capture for you. With the egge preview 6.1 update, it seems like is working better than in 6.0, but basically, the problem is that everything is moving when the document is ipad 3. When is ipad 2, all is ok.
Another thing is that the oem file seems like ignore the transparent background.
Hey there. Problem is that Safari has a default zooming for websites enabled. If you have to solve this immediately you have to set initial-scale: 1.0 to your Edge content HTML, if not, just wait for the next Edge preview which might improve this.
.oam has no transparency layer yet. This is a known issue which hoepfully will be resolved in an upcoming Edge preview.
