Hello everyone,
we recently upgraded from Coldfusion 8 to Coldfusion 10 and we found a business-stopping bug:
In Coldfusion 10 Administrator console go to DATA & SERVICES -> Web Services.
There add a web-service with WSDL link http://developer.ebay.com/webservices/latest/ebaySvc.wsdl
Other input values have no affect in this issue.
You will then receive a Coldfusion error:
Template: /CFIDE/Administrator/extensions/webservices.cfm
Diagnostics: javax.wsdl.Operation.getExtensionAttributes()Ljava/util/Map; null
The error occurred on line 141.
Same error if you try to instantiate an ebay web service object with given WSDL from inside the cfscript.
This is a serious show stopper since ebay API no longer work with Coldfusion 10 and we were forced to rollback to Coldfusion 8.
Any help would be highly appreciated!
P.S. other non-ebay WSDLs seem to add fine to CF10.
Adam, Consumption of the web service will also be impacted. The version decides which framework is used for generating the client side stubs.
DmitriD, could you please post the code used for testing. Where did you try to set the version? For consuming you should set the version in CFInvoke or CreateObject(). If you change the server level wsversion, it is used while publishing only.
<cfscript>
ws = createObject("webservice","http://developer.ebay.com/webservices/latest/ebaySvc.wsdl", {wsversion="1"});
WriteDump(ws);
</cfscript>
I tried the above code and it is working fine for me. Please check and let me know.
Paul
This worked Paul!
But how did you thought of that? I mean there's nothing said about wsversion in CreateObject tag (checked CF9 reference since there is no CreateObject reference for CF10 yet):
http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSc3ff6d0ea77859461 172e0811cbec22c24-6978.html
or in WSDL2Java Reference:
http://ws.apache.org/axis/java/reference.html#WSDL2JavaReference
I would never thought of that myself ![]()
Thank you very much Paul.
