Priyanka@Mediawide
how to highlight State of Multi-State object?
Jul 31, 2012 5:07 AM
Tags: #cs5.5
hi,
I have created 3 states of object State1, State2, State 3. and want to highlight state in object state panel programmatically. can any one have idea abt it?
    Jul 31, 2012 5:33 AM   in reply to Priyanka@Mediawide
    Hi there
    Select your multistate, then in the Object states panel, click through til the state you want - it's basically like a group within a group - so keep on clicking until you highlight the part you want!
    Tim
    Jul 31, 2012 5:50 AM   in reply to Priyanka@Mediawide
    Ahh I see! Sorry about that!
    I am also looking for some programming advice!
    Good Luck!
    Jul 31, 2012 6:05 AM   in reply to tim.hughes
    Are you on a Mac?
    There is a program called AppleScriptEditor
    if you open that, then go go
    file > open dictionary > Adobe Indesign CS"your version"
    It tells you all the apple script commands you can use with inDesign
    If you look through the dictionary to
    "Interactive Elements Suite" and then within that "multistate object" there are lots of things to choose from
    Maybe this is something worth looking at? (:
    Jul 31, 2012 10:03 AM   in reply to Priyanka@Mediawide
    @Priyanka – you did not mention a specific scripting language.
    In ExtendScript (JavaScript) you can set the "active" property of the 3rd state of your MultiStateObject to value "true".
    //ExtendScript (JavaScript) example
    //Make sure a MultiStateObject is selected; nothing else, then run this JavaScript:
    app.selection[0].states[2].active = true;
    The expression from left to wright (for lurkers who never saw a line of code):
    app => application (that's InDesign, of course)
    selection => your current selection in the UI (could be one item, could be many)
    [0] => index number 0 is the first item in your selection; be cautious with the expression "first", it depends on the InDesign version what that does exactly mean, if you selected more than one object
    states => obviously the "state" object (always with the plural "s", it's the collection of all states in that selected MultiStateObject)
    [2] => index number 2 is the 3rd element of the states collection
    active => property for the active status; boolean, could be "true" or "false"
    = => with the "=" sign, you are setting the value
    true => the value of the property; self-explanatory, I hope…
    ; => end of expression, all that comes after is a different expression.
    The different parts are held together with a dot-notation. The index  is directly glued to its object, no dot notation between object and index.
    If you want learn more about ExtendScript and the InDesign DOM see Jongwares' documentation at:
    http://www.jongware.com/idjshelp.html
    Uwe
