Hello, I need to manipulate Indesign client(open/close documents, create menus, tables, set colors etc... ) but I need to do that from a Java application. Is it possible? I was searching on google about it, even in Adobe's site, but the only way I found was thought Javascript, VbScript or AppleScript.
Thanks in advance! ![]()
Rafael
I can control inDesign from Python or shell scripts on osx via `osascript` This is roughly how it works.
Sorry I'm vague on real life code, but this is my home machine so it's not in my reach.
I realise it's an ugly hack. Main cons follow:
The only pro I can think of is that it works. Whole comlexicity is wrapped in one python module, which I only see when squashing the bugs.
Marcel
OK so here's what I use to run JSX file from shell
osascript -e 'tell application "Adobe InDesign CS5" to do script alias "%s" language javascript '''
where %s is path to the script.
There's probably a way to run an extendscript statement instead of a file, but my applescript skills are too limited for that. Besides it uses all sorts of quotation marks already.
Imagine escaping all quotes in your javascript and than escaping the whole thing before you call it from your Java, Python whatever app.
I've no idea what the visual basic equivalent for windows should look like, but I'm sure there's some VB guru around willing to help
(Slightly related) syntax sugar:
If you put this to your InDesign startup script:
#targetengine "session"
Application.prototype.shell = function (shell_script){ var apple_script = 'do shell script "' + shell_script + '"' var output = app.doScript (apple_script, ScriptLanguage.APPLESCRIPT_LANGUAGE) return output };
You will have `app.shell()` method available in any script executed in "session" targetengine. Now you can return your Java app favour and call it comfortably from Indesign ![]()
Hey Marcel,
I was searching Jacob and now I'm able to manipulate Indesign from my Java application. Here's a piece of code that show how I can do that:
//Call Indesign application
ActiveXComponent axIndesing = new ActiveXComponent("Indesign.Application");
//* Create a document
Dispatch documents = axIndesing.getProperty("Documents").toDispatch();
Dispatch document = Dispatch.get(documents, "Add").toDispatch();
// Create the document preferences
Dispatch documentPreferences = Dispatch.get(document, "DocumentPreferences").toDispatch();
Dispatch.put(documentPreferences, "pageHeight", "800pt");
Dispatch.put(documentPreferences, "pageWidth", "600pt");
//Dispatch.put(documentPreferences, "pageOrientation", "PageOrientation.landscape");
Dispatch.put(documentPreferences, "pagesPerDocument", 1);
I'm using the Adobe Indesign CS6 Tutorial to be able to implement that code. It's not big deal.
but thanks anyway, Dude for help me out! ![]()
obs: Just have to add the Jacob library to you java application
Rafael Paz
Yeah, thats correct, its for windows only. It's because our server is windows server. About "searching Jacob" sorry about that, I forgot to complete the setence: I mean, I was searching on google about Jacob library. Jacob is a library for Java, in other words is a Bridge where you can comunicate COM objects with an application.
thanks man! ![]()
My first attempt was an ExtendScript socket polled from within InDesign, and used to bounce scripts back and forth via eval() and/or Json. I found out the hard way though, that at least on OSX the last thing that ExtendScript will do is an attempt to write to a broken socket, whenever I prematurely close the other side e.g. by debugger kill. Besides CS5 idle events apparently stop working when InDesign is in background.
In a CS4 production environment I'm using a custom plugin for idle notifications, it also helps to pre-filter selection events to our purposes.
My latest experimental environment is Java on OSX which provides AppleScript as scripting engine (via javax.script), no need to use the shell or temporary files. I've been using it for a few months. With some glue code here and a few more wrapper objects there, it is fun to have a true IDE with Java code completion, javadoc help and syntax checking on InDesign scripts ...
Of course this setup comes at the cost of a slight speed penalty; I still have not found a good approach for methods that return variants (different types on different occasions) and objects that change their type on the fly are still a pain.
Thanks for the pointers to Jacob and Jawin, are there any experiences with j-Interop?
Dirk
Hello Dirk,
Well, I dont have experience with j-Interop, but if you wanna manipulate Indesign from a application(in my case Java) I suggest you JACOB. It's not a big deal, but you have to check Adobe Indesign CS6 Tutorial when you're coding. So you check how it's implemented in JavaScript and just transform this code in Java, for exemple:
To create a document in Javascrip t(Adobe Indesign CS6 Tutorial):
var myDocument = app.documents.add();
Now is just use JACOB and tranform this code like this:
Very simple, man!
Rafael Paz
We have not found cool alternative ![]()
As I remember I've found that some methods or properties were not implemented in stub generated with Jawin.
So we changed to InDesign Server. With SOAP you can relative easy start any script on Server.
But if Jacob is OK for your tasks, it's nice.
Cenchen, there is sample Java code in Adobe's InDesign Server SDK to send a SOAP request to an InDesign Server process started up to serve SOAP requests on a particular port number. Part of what you send in the SOAP request as a parameter is a path to a .JSX file to execute (either from the requesting side, or on the server side). You can get back a JavaScript result from that script in your Java that issues the SOAP request. Is what all you mean by wanting to call JavaScript from Java? Or is this something that you need to work also in InDesign desktop, not only the server verions?
(Perhaps you have already discovered these answers since your posting.)
There is also a load balancing scheme at least in CS6 using CORBA to make requests to the server.
