I'm trying to render out a comp with sound but the sound isn't rendering. I've checked the audio box which has always worked before. The sound plays fine in the comp under ram preview but when I render it out using mpeg2 there's no sound on the rendered file.
I'm worried the problem is down to an installation problem. I had to reinstall the production suite recently and there are problems with codecs missing from premiere. I have the Asus P8 P67pro motherboard and it's had a SATA controller failure. The motherboard is due to go back for replacement but I want to get this video finsihed first as I'll be without a computer for up to four weeks and unable to do any work.
Does this sound like a codecs issue? Is there any way I can get the sound working without a reinstall? I don't have any working dvd drive on this PC.
I'm using AE CS5. Windows 7 64bit
You can either render a losless file from AE for further compresion in Adobe Media Encoder, or you can open an AE comp in AME for encoding. Either way, it's better than doing it all in AE.
If you plan on using this animation elsewhere than on youtube, you'd be better off going the lossless route out of AE.
