When I view my web pages while in Dreamweaver, I need a piece of PHP code ( called ws_general.php ) to execute in order for the CSS to render.
The pages do look fine when in a browser but I would like to solve this to better test my pages while in Dreaweaver.
I have looked through various solutions but with no luck.
I am using: Windows 7 SP1
Dreamweaver CS6, build 5842
Murray,
The raw code at the top of my page is as follows:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<title>Jim Calvert Photographer - My Images</title>
<meta name="description" content="Photography has been a modest pastime for most of my adult life but recently became a serious passion. I feel very much at home outdoors in natural surroundings and enjoy the rewards of all-season photography">
<meta name="keywords" content="Jim Calvert, wildlife, photography, landscapes, Mississauga, Canada ">
<meta http-equiv="content-language" content="en-ca">
<meta name="copyright" content="Jim Calvert Photographer">
<meta name="company" content="Lanmax Computer Solutions Inc.">
<meta name="robots" content="index, follow">
<meta name="Language" content="English">
<link rel="stylesheet" type="text/css" media="all" href="ws_css/ws_general.php"> <<<<<<<<<<<< this is the php that needs to run !
<script type="text/javascript" src="ws_javascripts/rotator.js"></script>
<style type="text/css">
.style23 {
font-size: 1.4em
</style></head><body onload="rotateImage('RandPic')">
<div id="wrapper">
<div id="top">
......... etc, etc..
And the ws_general.php code is:
<?php
Burning Foliage Colour Scheme
Dark Green #394635
Green #6D7D59
MyGreen #2AB305
Light Green #B8C39E
Beige #F1F2DB
Light Beige #ECD77A
Light Brown #CD9644
Brown #8A5823
Dark Brown #513311
Very Dark Brown #1F1306
header("Content-type: text/css");
$main_bkgd = '#1F1306';
$def_text = '#F1F2DB';
$other_text = '#ECD77A';
$link_text = '#2AB305'; /* 2010.08.23 */
$borders = '#8A5823';
$titles = '#CD9644';
$def_menu = '#B8C39E';
/* Standard styles */
body {
position: relative;
text-align: left;
margin: 0;
padding: 0;
font:62.5% Georgia, Lucida Grande, Lucida Sans Unicode, trebuchet ms, Arial,Helvetica,sans-serif;
color: <?=$def_text?>;
background-color: <?=$main_bkgd?>;
background-position: top left;
background-repeat: repeat-x;
p {font-size: 1.2em; font-weight: normal; text-decoration: none; line-height: 1.7em; color:<?=$def_text?>; margin: 0; padding: 0 0 .7em 0; }
h1, h2, h3 {font-weight: normal; }
h1 {font-size: 1em; paddi..........etc, etc
Does this help?
Cheers
Yes - that helps. You will not see the CSS rendered in Design view when it is generated on the fly as you show here. However, you can make use of a design-time stylesheet to cause DW to explicitly load another stylesheet which is used to render the page for Design view. This "DT Stylesheet" would contain the rules/styles as generated from this PHP file. While not optimal (since there are two separate stylesheets involved here, you would have to keep them synched for your local display), it is quite workable. Does that help?
Is there a specific reason you are using php in there? It seems needlessly complex since all you're doing is defining CSS attributes with it.
I would turn it into a .css file, then move all of the defined colors and other attributes to their proper positions in place of the php snippets. That will work correctly in DW then.
