Editing paths
Jul 31, 2012 12:55 PM
    Jul 31, 2012 12:55 PM   in reply to Community Help
    I cannot move anchor points of a selected object.  When the object is selected and I use the direct selection tool to move an anchor point, it just moves the entire object.
    If the object is not selected I can use the direct selection tool and move an anchor point, but to use this approach requires continually deselecting the object first, which is time consuming. (CS5)
    Jul 31, 2012 1:02 PM   in reply to sarracenia
    It would help to understand what you're trying to do. Are you trying to edit the shape of a path?
    Whenever you have an object selected with the Selection tool, you can't edit the individual points of the path. You have to deselect (Cmd-Shift-A/Ctrl-Shift-A) and switch to the Direct Selection tool (press A). Click on the edge of the path so you see the hollow anchor points, click on the ones you want to affect, and move them.
    This is the way it has always worked, and is the same in Adobe Illustrator and in Adobe Photoshop.
    Perhaps I'm not understanding your problem. If so, can you explain it more fully, and perhaps provide a screen shot.
    Jul 31, 2012 1:17 PM   in reply to Steve Werner
    Thanks Steve.  Yes, I'm trying to move an anchor point to edit the shape of a path.
    In Illustrator I can move an anchor point if the object is already selected (click anchor point with direct select tool until cursor changes to the black mini-arrow -- not sure what it's called).  I seem to think that Indesign used to allow this but perhaps I'm mistaken.
    Jul 31, 2012 1:44 PM   in reply to sarracenia
    Not in InDesign. Illustrator is designed around path editing, for obvious reasons.
