This was a problem with Lightroom 2, was fixed in Lightroom 3, but has returned in Lightroom 4
Here's the scenerio
If you open a RAW file in Photoshop, just hit Save, it will save it as a PSD next to the RAW file in the same follder and that file will show up in the Library. But I like to keep my RAW files seperate from PSDs, Tiffs, and so forth.
Help!
Lincoln
Lightroom 4
Photoshop CS6 Extended
Mac OSX 10.7.4
Ian Lyons wrote:
Lr is capable of saving the tiff/psd/jpeg back into a new sub folder created by Photoshop. I've just checked and done it without any difficulty. Both the folder and image show up in Lr without having to use Synchronize Folder command.
Ian,
I can confirm most of that: starting with a raw file, using "Edit In...", then "save ss" within PS to save to a different folder. The derivative and new folder then appear in LR.....but only if I "save as" either a PSD or Tiff. If I attempt to "save as" a Jpeg, the derivative does NOT appear back in LR.
Are you saying that you do get the Jpeg added back into your LR catalog?
one comment: we can expect to see a difference when using "Edit in Photoshop", vs when using a named external editing preset from the Edit In... menu.
We may choose to use a preset in order to control the bitdepth, colourspace or filetype image-by-image; or when there are multiple editor programs in place.
In the former scenario, LR has told PS to open a file in memory and if this is not saved, LR makes no new image version. I am surprised that LR is "watching" to see where PS saves it aside from the default location and name - I was not aware that this channel of communication is available - but perhaps, this is just a question of a brand new file appearing at path B instead of at path A. So there is still only one file.
In the other case of using an external editing preset, I gather that LR will have already made a workfile on disk before PS opens, and then PS is passed the fixed location of that. So in this case a further "save as" by Photoshop will cause a separate file to exist - over and above the one which LR knows PS has opened. Even if PS is simply closed without saving changes, the image file in question is still present on disk, and also appears in LR unless/until removed.
