I have dropdown1 with items1-3. I have dropdown2 with items 1-10. When item1 is selected in dropdown1 I want dropdown2 to display all 10 items but some items be inaccessible(faded out) and not selectable.
(example)
item1 = [dropdown2] item 1 = selectable
[dropdown2] item 2 = selectable
[dropdown2] item 3 = selectable
[dropdown2] item 4 = not selectable
[dropdown2] item 5 = selectable
[dropdown2] item 6 = not selectable
and so on.
I have coded dropdown2 to populate based on items selected from dropdown1 but the problem is the user needs to see options that are not available for selection?
I am very new to FormCalc & Java any help would be greatly appreciated!! I am using LiveCycle Designer ES 8.2
Solved! Go to Solution.
Total Likes
Thanks to your help I have got it working now. I played around with your example here is your modified example of what I was trying to accomplish...https://dl.dropbox.com/u/12892158/Limit_DDL_Selection.pdf Thank you for your help.
Total Likes
you can do this with a script in the change event of the drop down box.
It will check the boundItem against the notUsed regular expression.
This example won't allow the selectio of item 1, 3, 4 and 8.
var notUsed = /1|3|4|8/;
if (this.boundItem(xfa.event.change).match(notUsed)) {
xfa.event.change = "";
Total Likes
Ok this may help me but I have a few issues. When I apply specfy item values then my dropdowns do not populate. So I have my values spelled out. So with that my code for dropdown1 goes as follows in the change event.
case "LS32CS - CSA Approved Switch":
DropDownList3.addItem("FLD - Field Config.")
DropDownList3.addItem("110 - 110VAC")
DropDownList3.addItem("220 - 220VAC")
DropDownList3.addItem("24D - 24VDC")
DropDownList3.addItem("24A - 24VAC")
break;
My question is can I empliment your code within this "case" like?
var notUsed = /DropDownList3.addItem("FLD - Field Config.")/;
break;
Total Likes
Total Likes
Thanks for the example, but your form doesnt work?
Total Likes
Here is my entire code for DDL1. In case "LS32CS - CSA Approved Switch": i do not want DropDownList3.addItem("FLD - Field Config.") to be selectable??
DropDownList3.clearItems();
var sNewSel = this.boundItem(xfa.event.newText);
switch (sNewSel)
case "VS5100 - Dual Channel VERSA-SWITCH":
break;
case "VS51NX - Dual Channel Non Explosion Proof":
break;
case "LS51SC - Single Channel Level Switch":
break;
case "LS51NX - Single Channel Level Non Explosion Proof":
break;
break;
case "LS32CN - CENELEC Approved Switch":
break;
case "LS32NX - Non Explosion Proof Switch":
break;
default:
break;
Total Likes
Total Likes
Lets take this a step further. once an item has been selected in DD1 I want to make the Items that are not selectable in DD2 "faded out" or "watermarked". Where would we insert the font.attributes?
Total Likes
