I'm new to Dreamweaver. I need to replace some PDFs that have outdated information. I created new PDFs, saved them to the root, broke the old link, made a new link, connecting the new PDF, selected ctrl + double click to open the PDF to make sure it was there, saved the file, and put the file up. Then, when I open the changed links in the browser, I get a 404. When I go back to reconnect the old, outdated links, they work, but none of the new links do. It's definitely a user error--I can't find any resources to help me past the problem and I absolutely cannot see what I am doing differently or wrong. It's making me crazy! I hope you can help! Thanks!
Either the path to the PDF http://campfireusa-mn.org/Events/2012sponsorshipjuly.pdf is wrong
or the PDF is not located in the Events folder on the server (has it accidentally been uploaded to the root directory or another folder?)
or the name of the PDF is different
Thank you for your comments. I think it is a path issue, but I don't know how to fix. I'm sure it's something simple too. I saved the PDFs to the same folders that had the old PDFs.
They appear as though they are uploaded correctly into dreamweaver. I can see them in the root directory within their respective folders, and when I select the text that makes the link, the link appears at the bottom of the screen so it looks as though it will be published correctly, but then it isn't.
