A Problem with LR 4.1 update
Jul 31, 2012 12:33 PM
With Lightroom 4.0 (64 bits), everything goes normal. When I clicked "Edit in Adobe Photoshop CS5.." the edited raw file was exported to CS5 photoshop in "tif" format.
After updating Lightroom 4.1 today, LR no longer generates "DSC-1234-Edit.tif" and exports to CS5 photoshop in "NEF" format.  It appears that there is a problem with LR4.
How can I fix this problem?     I am running Windows 7 Pro (64 bit)  with 8 GB RAM.
    Jul 31, 2012 12:39 PM   in reply to hummer777
    It isn't a problem, and it isn't anything that you should worry about.  Lightroom 4.1 is compatible with ACR 6.7, which is compatible with more cameras.  You really are not working on the raw image data.  That only indicates where the data came from.  Since Lightroom and ACR are compatible, the creation of the TIF file will be done at the end of the Photoshop session rather than at the beginning.  Everything is working the way it should.
    Jul 31, 2012 1:20 PM   in reply to JimHess
    That is (Lr4.1) the expected behaviour, the Lr4 behaviour is for when Lr and PS/ACR are out of sequence.
    Jul 31, 2012 1:34 PM   in reply to hummer777
    Lightroom does not create a TIFF/PSD when opening a file in PS if the versions are aligned as you have with your set up of Lr4.1. The TIFF is created when the data open in PS is saved.
    Jul 31, 2012 1:54 PM   in reply to hummer777
    When Lightroom and Photoshop/ACR are out of sync, the TIF file has to be created first in order to include all of the Lightroom adjustments.  If the programs ARE in sync, then ACR is able to translate the Lightroom adjustments to and pass them on to Photoshop.  The TIF file doesn't have to be created until the end of the Photoshop editing session.  It's working the way it is supposed to, and there is nothing you can or should do to change it.  Really.
    Jul 31, 2012 2:15 PM   in reply to hummer777
    I realize that when you are in Photoshop it will appear as though you are working on the NEF, but when you save your work in Photoshop it will save the TIF or PSD, depending on your Lightroom preferences.
    Jul 31, 2012 3:11 PM   in reply to hummer777
    You sound surprised.
