CF 10 Developer Edition.
Windows XP SP3
When submitting a page that worked fine in CF 7 on this machine, I get an error I've never seen before:
HTTP STATUS 500-
description: The server encountered an internal error () that prevented it from fulfilling this request.
exception:
javax.servlet.ServletException: ROOT CAUSE: java.lang.IllegalStateException: Cannot call sendError() after the response has been committed at org.apache.catalina.connector.ResponseFacade.sendError(ResponseFacade .java:451) at javax.servlet.http.HttpServletResponseWrapper.sendError(HttpServletRe sponseWrapper.java:120) at coldfusion.tagext.io.cache.ehcache.GenericResponseWrapper.sendError(G enericResponseWrapper.java:91) at coldfusion.filter.FormScope.parseQueryString(FormScope.java:501)
etcetera, which ends in
note The full stack trace of the root cause is available in the Apache Tomcat/7.0.23 logs.
I can't seem to be able to debug or localize this error: cfabort placed in strategic places doesn't help at all, and none of my usual tricks work. The debug info is not displayed when this error happens (although the server is set to display debug info, and it normally does).
Totally puzzled,
LBPSlava
First, this discussion fixed my problem. Customers of ours had a number of forms with more than 100 fields. This is CF setting is new and honestly, I think 100 is too low. 500 should be the default.
it's not cool to find out about this option from errors in a production server. Better to make the default higher, then admins can lower it if they want rather than cause chaos until this new buried option is discovered.
Please Adobe consider increasing this default value, while on the surface it's seemingly high, we have a product that creates a lot of hidden fields...
