DBAmann
Form Export + Form and Response deletes + Form Import = Missing Column Headers
Jul 31, 2012 12:29 PM
Tags: #missing #after #import #headers #titles #column
As part of a recovery test here are the steps performed.
1) Build Form
2) Form Export (save to local laptop)
3) Delete View Responses
4) Delete Form also
5) Environment is now completely clean
6) Import Form (backup is on local laptop)
7) Use the Form (works perfectly)
8) Check View Response results (oops . . . Column Headers are missing)
9) All the expected data is completely there
10) But the View Response Column Header (titles) are gone.
11) History is meaningless because of Step 4
Summary:
The form is completely and totally restored and correctly operational and all expected data is complete and exists, but the View Response Column Headers (titles) are not restored from Step 6 nor re-added from Step 7.
Problem:
So, how do I reload Column Headers after an Import???
    Jul 31, 2012 1:13 PM   in reply to DBAmann
    Sorry about the problem, to help better understand the issue, couple questions:
    - in step "2) Form Export", do you use File->Export Design File... ?
    - in step "9) All the expected data is completely there", you don't expect to see row data, only columns, right? (when using Design File export we only preserve information about fields, but not response data)
    - can you send me in private your exported file, so I can test it more
    Roman
    Jul 31, 2012 4:57 PM   in reply to DBAmann
    Just to clarify, when you use File->Export Design File...  we would NOT save any response data, for example, if you have the following data:
    where we have two responses: John:123 and Dave:456.
    Now if you export this form, delete it and reimport again, the response data would be gone, so you will see:
    Basically File->Export Design File... would only save form's fields but not actual responses.
    I could not reproduce the issue with columns, I can see column headers after import (in above picture: Name/Phone still there)
    Can you please send the design file directly to my email: rdolgov@adobe.com , so I can try to reproduce the problem.
    Roman
    Jul 31, 2012 9:19 PM   in reply to DBAmann
    Thanks for clarification, we should restore column headers information during design file import, but looks like due some issues it's not working in this case. Can you please send me your .fcdt file to my email: rdolgov@adobe.com so we can debug the problem.
    Roman
    Aug 1, 2012 4:30 PM   in reply to DBAmann
    Just a note, that if you cleared column headers (in the response table) before the export, we would not restore headers text in the response table. For example if you selected all rows (including header row) and pressed DELETE we would erase all headers text from the response table (but not from the design tab, where all fields still would keep header labels)
    Generally, we keep syncing text from the design tab/field label to the responses table/column header only if the column header (in the responses table) wasn't directly modified.
    Not sure if this what happened in this case, but I can try to verify if you can send me the .fcdt file.
    thanks
    Roman
