When I use Dreamweaver to upload a file very often something gets corrupt. Javascript ceases to work. The page runs locally and javascript works. The file is fine when I upload with a different ftp tool (fetch, Transmit, etc).
When I view the source of the non-working file the code looks all garbled.
When I upload the file witha diftterent ftp tool, all is well.
Never saw this before. What's up?
Using Mac, Lion, latest versions.
Have you installed the 12.0.1 update which Adobe says addresses some FTP issues?
https://blogs.adobe.com/dreamweaver/2012/07/dreamweaver-cs6-update-12- 0-1.html
You can see a sample page here
The js is a simple date script I've been using for years.
Check out the formatting change after the upload with CS6 - This ONLY happens with CS6.
Server - Linux, apache 2.2.22
Local - iMac 2.8ghz core i7 OS 10.8
Thanks for the tip. I was also set to Macintosh. I changed to Unix and resaved a script and it so far seems to have solved the problem. I'll keep testing. Hopefully I can start to use the Dreamweaver FTP tool again.
But for the record I was also having this problem in CS5 (although less consistently).
