amitchzone
Strange Output messages and response, Flash CS5
Jul 31, 2012 12:55 PM
Tags: #cs5 #flash #display #output
I've had some issues with flash files opening up partially and then Flash CS5 crashing completely. After opening a different file, then trying to open the file I want, everything seems fine.
Today, however, after opening one of these files, I found my stage to be blank. The timeline was filled as I had created my movie and my code and if I put my mouse on the stage, the properties window showed that i had selected an item. I can also select a symbol in the libaray and have it display above.  Publishing works as well, but then I get a long output message that I've googled with not much in the way of results.  (Displayed below)
This is also occuring with totally unrelated filash files.  I've also go to the extent of copying a timeline, pasted into a new flash file but have had the same result.  I had a co-worker open the file on their machine and everything was fine.
I've also tried creating a new flash file, create new sybols and have had nothing show on the stage until I publish to test the file.  then get something.
I've uninstalled and reinstalled Flash...no luck. I've also removed the prefs and rebooted as well...still no luck.
Any help would be great.  I'm pretty sure it's related to my copy of Flash so if there's something else I can try with reinstalling or the prefs or something, please advise.
verify version::implements if()
                        stack:
                        scope: [global Object$ flash.events::EventDispatcher$ flash.display::DisplayObject$ flash.display::InteractiveObject$ flash.display::DisplayObjectContainer$ flash.display::Sprite$ flash.display::MovieClip$ version::implements if$] ~ ~ ~ ~ ~
                         locals: version::implements if * * * *
  0:getlocal0
                        stack: version::implements if
  1:pushstring ""
                        stack: version::implements if String
  3:setslot 4
                        stack:
  5:getlocal0
  6:pushstring ""
  8:setslot 5
                        stack:
  10:getlocal0
  11:pushstring ""
  13:setslot 6
                        stack:
  15:getlocal0
  16:pushstring ""
  18:setslot 8
                        stack:
  20:abs_jump 1394217225 1145
            exception[0] from=252 to=1123 target=1127 type=Error name=e
                        stack:
  0:pushfalse
                        stack: Boolean
  1:pushtrue
                        stack: Boolean Boolean
  2:setlocal3
                        stack: Boolean
                         locals: version::implements if * * Boolean *
  3:newfunction method_id=3465 Function/<anonymous>
                        stack: Boolean Function
  6:pop
                        stack: Boolean
  7:jump 23
                        stack: Boolean
- 11:pushwith
                        stack: Boolean
- 12:setlocal3
                        stack: Boolean
- 13:strictequals
                        stack: Boolean
- 14:getlocal2
                        stack: Boolean
- 15:convert_s
                        stack: Boolean
- 16:getlocal1
                        stack: Boolean
- 17:inclocal 3
                        stack: Boolean
- 19:kill 3
                        stack: Boolean
- 21:kill 2
B23:
                        stack: Boolean
  23:setlocal 4
                        stack:
                         locals: version::implements if * * Boolean Boolean
  25:getlocal0
  26:pushscope
                        stack:
                        scope: [global Object$ flash.events::EventDispatcher$ flash.display::DisplayObject$ flash.display::InteractiveObject$ flash.display::DisplayObjectContainer$ flash.display::Sprite$ flash.display::MovieClip$ version::implements if$] version::implements if ~ ~ ~ ~
  27:newactivation
  28:dup
                        stack: version::implements if version::implements if
  29:setlocal1
                         locals: version::implements if version::implements if * Boolean Boolean
  30:pushscope
                        stack:
                        scope: [global Object$ flash.events::EventDispatcher$ flash.display::DisplayObject$ flash.display::InteractiveObject$ flash.display::DisplayObjectContainer$ flash.display::Sprite$ flash.display::MovieClip$ version::implements if$] version::implements if version::implements if ~ ~ ~
  31:getlocal 4
                        stack: Boolean
  33:not
                        stack: Boolean
  34:iffalse 246
                        stack:
  38:getscopeobject 1
  40:pushnull
                        stack: version::implements if null
  41:coerce flash.utils::ByteArray
                        stack: version::implements if flash.utils::ByteArray?
  43:setslot 1
                        stack:
  45:getlocal 4
                        stack: Boolean
  47:iftrue 169
                        stack:
  51:getlocal 4
                        stack: Boolean
  53:iffalse 209
                        stack:
  57:getlocal1
  58:getlocal2
                        stack: version::implements if *
  59:getlocal0
                        stack: version::implements if * version::implements if
  60:kill 1
  62:kill 2
  64:kill 0
                         locals: * * * Boolean Boolean
  66:setlocal0
  67:setlocal2
  68:setlocal1
B69:
                        stack:
                         locals: version::implements if? version::implements if? * Boolean Boolean
  69:label
                        stack:
  70:getlocal0
                        stack: version::implements if?
  71:getlex 1765
                        stack: version::implements if? flash.system::Capabilities$?
  74:getproperty isDebugger
                        stack: version::implements if? Boolean
  77:initproperty *::try var
                        stack:
  80:getlocal3
                        stack: Boolean
  81:not
                        stack: Boolean
  82:iftrue 246
                        stack:
  86:getlocal 4
                        stack: Boolean
  88:iffalse 187
                        stack:
  92:getlocal 4
                        stack: Boolean
  94:getlocal3
  95:getlocal0
                        stack: Boolean Boolean version::implements if?
  96:kill 4
                         locals: version::implements if? version::implements if? * Boolean *
  98:kill 3
                         locals: version::implements if? version::implements if? * * *
  100:kill 0
                         locals: * version::implements if? * * *
  102:setlocal0
  103:setlocal3
                        stack: Boolean
  104:setlocal 4
B106:
                        stack:
  106:label
                        stack:
  107:getlex 1927
                        stack: flash.system::Security$?
  110:pushstring "*"
                        stack: flash.system::Security$? String
  112:callpropvoid allowDomain 1
                        stack:
  116:getlocal 4
                        stack: Boolean
  118:iftrue 246
                        stack:
  122:getlocal 4
                        stack: Boolean
  124:not
                        stack: Boolean
  125:iffalse 190
                        stack:
  129:getlocal3
                        stack: Boolean
  130:iftrue 237
                        stack:
  134:getlocal3
                        stack: Boolean
  135:getlocal1
                        stack: Boolean version::implements if?
  136:getlocal0
                        stack: Boolean version::implements if? version::implements if?
  137:kill 3
                         locals: version::implements if? version::implements if? * * Boolean
  139:kill 1
                         locals: version::implements if? * * * Boolean
  141:kill 0
                         locals: * * * * Boolean
  143:setlocal0
  144:setlocal1
                        stack: Boolean
  145:setlocal3
B146:
                        stack:
  146:label
                        stack:
  147:getscopeobject 1
  149:pushnull
  150:coerce com.hurlant.crypto.symmetric::IVMode
                        stack: version::implements if com.hurlant.crypto.symmetric::IVMode?
  153:setslot 3
                        stack:
  155:getlocal 4
                        stack: Boolean
  157:not
                        stack: Boolean
  158:iffalse 246
                        stack:
  162:getlocal 4
                        stack: Boolean
  164:not
                        stack: Boolean
  165:iffalse 217
B169:
                        stack:
  169:getlocal 4
                        stack: Boolean
  171:iffalse 69
                        stack:
  175:getlocal1
  176:getlocal2
                        stack: version::implements if? *
  177:getlocal0
                        stack: version::implements if? * version::implements if?
  178:kill 1
                         locals: version::implements if? * * Boolean Boolean
  180:kill 2
  182:kill 0
  184:setlocal0
  185:setlocal2
  186:setlocal1
B187:
                        stack:
  187:getlocal0
  188:constructsuper 0
B190:
                        stack:
  190:getlocal3
                        stack: Boolean
  191:iftrue 106
                        stack:
  195:getlocal0
  196:getlocal 4
  198:getlocal1
                        stack: version::implements if? Boolean version::implements if?
  199:kill 0
                         locals: * version::implements if? * Boolean Boolean
  201:kill 4
                         locals: * version::implements if? * Boolean *
  203:kill 1
                         locals: * * * Boolean *
  205:setlocal1
  206:setlocal 4
  208:setlocal0
B209:
                        stack:
  209:getscopeobject 1
  211:pushnull
  212:coerce com.hurlant.crypto.symmetric::IPad
                        stack: version::implements if com.hurlant.crypto.symmetric::IPad?
  215:setslot 2
B217:
                        stack:
  217:getlocal 4
                        stack: Boolean
  219:iffalse 146
                        stack:
  223:getlocal1
  224:getlocal 4
  226:getlocal0
  227:kill 1
  229:kill 4
                         locals: version::implements if? * * Boolean *
  231:kill 0
  233:setlocal0
  234:setlocal 4
  236:setlocal1
B237:
                        stack:
  237:getlex 1927
  240:pushstring "*"
  242:callpropvoid allowInsecureDomain 1
B246:
                        stack:
  246:getlocal 4
                        stack: Boolean
  248:iffalse 252
B252:
                        stack:
  252:getscopeobject 1
  254:getlex 1114
                        stack: version::implements if com.hurlant.util::Hex$?
  257:getlex 1114
                        stack: version::implements if com.hurlant.util::Hex$? com.hurlant.util::Hex$?
  260:getlex 1872
                        stack: version::implements if com.hurlant.util::Hex$? com.hurlant.util::Hex$? ___-5$?
  263:pushint -1549581749
                        stack: version::implements if com.hurlant.util::Hex$? com.hurlant.util::Hex$? ___-5$? int
  266:getlocal3
                        stack: version::implements if com.hurlant.util::Hex$? com.hurlant.util::Hex$? ___-5$? int Boolean
  267:iftrue 281
  271:pushbyte 36
                        stack: version::implements if com.hurlant.util::Hex$? com.hurlant.util::Hex$? ___-5$? int int
  273:multiply_i
  274:pushbyte 102
  276:subtract_i
  277:pushbyte 28
  279:add_i
  280:increment_i
B281:
  281:callproperty ___-O 1
                        stack: version::implements if com.hurlant.util::Hex$? com.hurlant.util::Hex$? String?
  285:coerce_s
  286:callproperty fromString 1
                        stack: version::implements if com.hurlant.util::Hex$? String?
  290:callproperty toArray 1
  294:coerce flash.utils::ByteArray
  296:setslot 1
                        stack:
  298:getlocal3
                        stack: Boolean
  299:not
                        stack: Boolean
  300:iftrue 660
                        stack:
  304:getscopeobject 1
  306:findpropstrict com.hurlant.crypto.symmetric::NullPad
                        stack: version::implements if global
  309:constructprop 1169 0
                        stack: version::implements if com.hurlant.crypto.symmetric::NullPad
  313:coerce com.hurlant.crypto.symmetric::IPad
  316:setslot 2
                        stack:
  318:getlocal 4
                        stack: Boolean
  320:not
                        stack: Boolean
  321:iffalse 660
                        stack:
  325:getlocal3
                        stack: Boolean
  326:iftrue 418
                        stack:
  330:getlocal1
  331:getlocal1
                        stack: version::implements if? version::implements if?
  332:getlocal3
                        stack: version::implements if? version::implements if? Boolean
  333:kill 1
  335:kill 1
  337:kill 3
  339:setlocal3
  340:setlocal1
  341:setlocal1
B342:
                        stack:
  342:label
                        stack:
  343:getscopeobject 1
  345:getslot 3
                        stack: com.hurlant.crypto.symmetric::IVMode?
  347:getlex 1114
                        stack: com.hurlant.crypto.symmetric::IVMode? com.hurlant.util::Hex$?
  350:getlex 1114
                        stack: com.hurlant.crypto.symmetric::IVMode? com.hurlant.util::Hex$? com.hurlant.util::Hex$?
  353:getlex 1872
                        stack: com.hurlant.crypto.symmetric::IVMode? com.hurlant.util::Hex$? com.hurlant.util::Hex$? ___-5$?
  356:pushint -1549581748
                        stack: com.hurlant.crypto.symmetric::IVMode? com.hurlant.util::Hex$? com.hurlant.util::Hex$? ___-5$? int
  359:getlocal3
                        stack: com.hurlant.crypto.symmetric::IVMode? com.hurlant.util::Hex$? com.hurlant.util::Hex$? ___-5$? int Boolean
  360:iftrue 379
  364:increment_i
  365:pushbyte 48
                        stack: com.hurlant.crypto.symmetric::IVMode? com.hurlant.util::Hex$? com.hurlant.util::Hex$? ___-5$? int int
  367:subtract_i
  368:pushbyte 41
  370:multiply_i
  371:pushbyte 72
  373:multiply_i
  374:decrement_i
  375:increment_i
  376:pushbyte 65
  378:add_i
B379:
  379:callproperty ___-O 1
                        stack: com.hurlant.crypto.symmetric::IVMode? com.hurlant.util::Hex$? com.hurlant.util::Hex$? String?
  383:coerce_s
  384:callproperty fromString 1
                        stack: com.hurlant.crypto.symmetric::IVMode? com.hurlant.util::Hex$? String?
  388:callproperty toArray 1
                        stack: com.hurlant.crypto.symmetric::IVMode? flash.utils::ByteArray?
  392:setproperty IV
                        stack:
  395:getlocal3
                        stack: Boolean
  396:iffalse 600
                        stack:
  400:getlocal 4
                        stack: Boolean
  402:iffalse 545
                        stack:
  406:getlocal2
                        stack: *
  407:getlocal3
                        stack: * Boolean
  408:getlocal0
                        stack: * Boolean version::implements if?
  409:kill 2
  411:kill 3
  413:kill 0
                         locals: * version::implements if? * * Boolean
  415:setlocal0
                        stack: * Boolean
  416:setlocal3
                        stack: *
  417:setlocal2
B418:
                        stack:
  418:getlocal0
  419:getlex 2404
                        stack: version::implements if? com.hurlant.crypto::Crypto$?
  422:getlex 1872
                        stack: version::implements if? com.hurlant.crypto::Crypto$? ___-5$?
  425:pushint -1549581745
                        stack: version::implements if? com.hurlant.crypto::Crypto$? ___-5$? int
  428:getlocal 4
                        stack: version::implements if? com.hurlant.crypto::Crypto$? ___-5$? int Boolean
  430:iffalse 444
  434:pushbyte 24
                        stack: version::implements if? com.hurlant.crypto::Crypto$? ___-5$? int int
  436:add_i
  437:pushbyte 113
  439:multiply_i
  440:pushbyte 17
  442:subtract_i
  443:negate_i
B444:
  444:callproperty ___-O 1
                        stack: version::implements if? com.hurlant.crypto::Crypto$? String?
  448:coerce_s
  449:getscopeobject 1
                        stack: version::implements if? com.hurlant.crypto::Crypto$? String? version::implements if
  451:getslot 1
                        stack: version::implements if? com.hurlant.crypto::Crypto$? String? flash.utils::ByteArray?
  453:getscopeobject 1
                        stack: version::implements if? com.hurlant.crypto::Crypto$? String? flash.utils::ByteArray? version::implements if
  455:getslot 2
                        stack: version::implements if? com.hurlant.crypto::Crypto$? String? flash.utils::ByteArray? com.hurlant.crypto.symmetric::IPad?
  457:callproperty getCipher 3
                        stack: version::implements if? com.hurlant.crypto.symmetric::ICipher?
  461:initproperty *::cipher
                        stack:
  464:getlocal3
                        stack: Boolean
  465:not
                        stack: Boolean
  466:iftrue 950
                        stack:
  470:getlocal 4
                        stack: Boolean
  472:iffalse 490
                        stack:
  476:getlocal 4
                        stack: Boolean
  478:getlocal1
  479:getlocal2
                        stack: Boolean version::implements if? *
  480:kill 4
  482:kill 1
  484:kill 2
  486:setlocal2
  487:setlocal1
                        stack: Boolean
  488:setlocal 4
B490:
                        stack:
  490:getscopeobject 1
  492:getlocal0
                        stack: version::implements if version::implements if?
  493:getproperty *::cipher
                        stack: version::implements if com.hurlant.crypto.symmetric::ICipher?
  496:getlex 263
                        stack: version::implements if com.hurlant.crypto.symmetric::ICipher? com.hurlant.crypto.symmetric::IVMode$?
  499:astypelate
  500:coerce com.hurlant.crypto.symmetric::IVMode
  503:setslot 3
                        stack:
  505:getlocal3
                        stack: Boolean
  506:not
                        stack: Boolean
  507:iftrue 950
                        stack:
  511:getlocal 4
                        stack: Boolean
  513:iffalse 342
                        stack:
  517:getlocal0
  518:getlocal0
  519:getlocal1
                        stack: version::implements if? version::implements if? version::implements if?
  520:jump 536
- 524:declocal_i 3
- 526:declocal_i 3
- 528:getlocal3
- 529:multiply
- 530:divide
- 531:getlocal3
- 532:convert_s
- 533:convert_i
- 534:inclocal_i 3
B536:
  536:kill 0
  538:kill 0
  540:kill 1
  542:setlocal1
  543:setlocal0
  544:setlocal0
B545:
                        stack:
  545:getlex 632
                        stack: flash.external::ExternalInterface$?
  548:getproperty available
                        stack: Boolean
  551:iffalse 1123
                        stack:
  555:getlocal 4
                        stack: Boolean
  557:iftrue 1104
                        stack:
  561:getlocal 4
                        stack: Boolean
  563:iffalse 567
B567:
                        stack:
  567:getlex 50
                        stack: flash.display::Stage?
  569:coerce_a
                        stack: *
  570:convert_b
                        stack: Boolean
  571:getlocal 4
  573:iftrue 592
                        stack: Boolean
  577:dup
  578:getlocal3
                        stack: Boolean Boolean Boolean
  579:iffalse 615
  583:iffalse 614
                        stack: Boolean
  587:getlocal3
  588:iffalse 885
B592:
                        stack: Boolean
  592:pop
                        stack:
  593:getlocal 4
                        stack: Boolean
  595:not
                        stack: Boolean
  596:iffalse 1118
B600:
                        stack:
  600:getlex 50
  602:getproperty loaderInfo
                        stack: flash.display::LoaderInfo?
  605:coerce_a
                        stack: *
  606:convert_b
                        stack: Boolean
  607:getlocal 4
  609:not
  610:iffalse 626
B614:
                        stack: Boolean
  614:dup
B615:
  615:iffalse 649
                        stack: Boolean
  619:getlocal 4
  621:not
  622:iffalse 885
B626:
                        stack: Boolean
  626:pop
                        stack:
  627:getlocal 4
                        stack: Boolean
  629:iftrue 774
                        stack:
  633:getlex 50
  635:getproperty loaderInfo
  638:getproperty parameters
                        stack: Object?
  641:convert_b
                        stack: Boolean
  642:getlocal 4
  644:not
  645:iffalse 1108
B649:
                        stack: Boolean
  649:iffalse 1123
                        stack:
  653:getlocal 4
                        stack: Boolean
  655:not
                        stack: Boolean
  656:iffalse 894
B660:
                        stack:
  660:getlex 50
  662:getproperty loaderInfo
  665:getproperty parameters
                        stack: Object?
  668:getproperty {*,public,*,version,version,http://adobe.com/AS3/2006/builtin,version :implements if,version:implements if,flash.display:MovieClip,flash.display:Sprite,flash.display:Display ObjectContainer,flash.display:InteractiveObject,flash.display:DisplayO bject,flash.events:EventDispatcher}::callFlashPlayerReady
                        stack: *
  671:pushstring "true"
                        stack: * String
  674:ifne 1123
                        stack:
  678:getlocal 4
                        stack: Boolean
  680:iftrue 1006
                        stack:
  684:getlex 1927
  687:pushstring "http://www.o-minds.com/payment-gateway/crossdomain.xml"
  690:callpropvoid loadPolicyFile 1
                        stack:
  694:getlocal3
                        stack: Boolean
  695:iffalse 855
                        stack:
  699:getlocal3
                        stack: Boolean
  700:iftrue 718
                        stack:
  704:getlocal 4
                        stack: Boolean
  706:getlocal2
                        stack: Boolean *
  707:getlocal2
                        stack: Boolean * *
  708:kill 4
                        stack: Boolean * *
  710:kill 2
                        stack: Boolean * *
  712:kill 2
                        stack: Boolean * *
  714:setlocal2
                        stack: Boolean *
  715:setlocal2
                        stack: Boolean
  716:setlocal 4
B718:
                        stack:
  718:getlocal0
  719:getlex 50
                        stack: version::implements if? flash.display::Stage?
  721:getproperty loaderInfo
                        stack: version::implements if? flash.display::LoaderInfo?
  724:getproperty parameters
                        stack: version::implements if? Object?
  727:getproperty {*,public,*,version,version,http://adobe.com/AS3/2006/builtin,version :implements if,version:implements if,flash.display:MovieClip,flash.display:Sprite,flash.display:Display ObjectContainer,flash.display:InteractiveObject,flash.display:DisplayO bject,flash.events:EventDispatcher}::email
  730:initproperty *::email
                        stack:
  733:getlocal3
                        stack: Boolean
  734:iffalse 950
                        stack:
  738:getlocal 4
                        stack: Boolean
  740:iffalse 840
                        stack:
  744:getlocal 4
                        stack: Boolean
  746:getlocal1
  747:getlocal1
  748:kill 4
  750:kill 1
  752:kill 1
  754:setlocal1
  755:setlocal1
                        stack: Boolean
  756:setlocal 4
B758:
                        stack:
  758:label
                        stack:
  759:getlocal0
  760:getlocal0
  761:callproperty if const 0
  765:initproperty *::const finally
                        stack:
  768:getlocal 4
                        stack: Boolean
  770:iftrue 1118
B774:
                        stack:
  774:getlocal3
                        stack: Boolean
  775:iftrue 874
                        stack:
  779:getlocal2
                        stack: *
  780:getlocal 4
                        stack: * Boolean
  782:getlocal1
  783:kill 2
  785:kill 4
  787:kill 1
  789:setlocal1
                        stack: * Boolean
  790:setlocal 4
                        stack: *
  792:setlocal2
B793:
                        stack:
  793:label
                        stack:
  794:getlocal0
  795:getlex 50
  797:getproperty loaderInfo
  800:getproperty parameters
  803:getproperty {*,public,*,version,version,http://adobe.com/AS3/2006/builtin,version :implements if,version:implements if,flash.display:MovieClip,flash.display:Sprite,flash.display:Display ObjectContainer,flash.display:InteractiveObject,flash.display:DisplayO bject,flash.events:EventDispatcher}::sender
  806:initproperty *::sender
                        stack:
  809:getlocal 4
                        stack: Boolean
  811:iftrue 911
                        stack:
  815:getlocal 4
                        stack: Boolean
  817:not
                        stack: Boolean
  818:iffalse 855
                        stack:
  822:getlocal 4
                        stack: Boolean
  824:iffalse 758
                        stack:
  828:getlocal3
                        stack: Boolean
  829:getlocal2
                        stack: Boolean *
  830:getlocal0
                        stack: Boolean * version::implements if?
  831:kill 3
  833:kill 2
  835:kill 0
  837:setlocal0
                        stack: Boolean *
  838:setlocal2
                        stack: Boolean
  839:setlocal3
B840:
                        stack:
  840:getlocal0
  841:getlex 50
  843:getproperty loaderInfo
  846:getproperty parameters
  849:getproperty {*,public,*,version,version,http://adobe.com/AS3/2006/builtin,version :implements if,version:implements if,flash.display:MovieClip,flash.display:Sprite,flash.display:Display ObjectContainer,flash.display:InteractiveObject,flash.display:DisplayO bject,flash.events:EventDispatcher}::key
  852:initproperty *::key
B855:
                        stack:
  855:getlocal3
                        stack: Boolean
  856:iftrue 793
                        stack:
  860:getlocal3
                        stack: Boolean
  861:getlocal 4
  863:getlocal3
  864:kill 3
  866:kill 4
  868:kill 3
  870:setlocal3
  871:setlocal 4
                        stack: Boolean
  873:setlocal3
B874:
                        stack:
  874:getlocal0
  875:getproperty *::const finally
                        stack: Boolean
  878:getlocal 4
  880:not
  881:iffalse 940
B885:
                        stack: Boolean
  885:iffalse 915
                        stack:
  889:getlocal3
                        stack: Boolean
  890:iffalse 911
B894:
                        stack:
  894:getlocal 4
                        stack: Boolean
  896:iffalse 900
B900:
                        stack:
  900:getlocal0
  901:pushfalse
  902:initproperty *::isPro
                        stack:
  905:getlocal 4
                        stack: Boolean
  907:iftrue 930
B911:
                        stack:
  911:jump 930
B915:
                        stack:
  915:getlocal0
  916:getlocal0
  917:callproperty version::----___ 0
  921:initproperty *::isPro
                        stack:
  924:getlocal 4
                        stack: Boolean
  926:iftrue 1024
B930:
                        stack:
  930:getlocal0
  931:getproperty *::isPro
                        stack: Boolean
  934:getlocal3
  935:not
  936:iftrue 1108
B940:
                        stack: Boolean
  940:iftrue 1010
                        stack:
  944:getlocal3
                        stack: Boolean
  945:not
                        stack: Boolean
  946:iftrue 1118
B950:
                        stack:
  950:getlex 632
  953:pushstring "activatePro"
                        stack: flash.external::ExternalInterface$? String
  956:getlocal0
                        stack: flash.external::ExternalInterface$? String version::implements if?
  957:getproperty *::try var
                        stack: flash.external::ExternalInterface$? String Boolean
  960:getlocal0
                        stack: flash.external::ExternalInterface$? String Boolean version::implements if?
  961:getproperty *::isPro
                        stack: flash.external::ExternalInterface$? String Boolean Boolean
  964:getlocal0
                        stack: flash.external::ExternalInterface$? String Boolean Boolean version::implements if?
  965:getproperty *::email
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String?
  968:getlocal0
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String? version::implements if?
  969:getproperty *::key
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String? String?
  972:getlocal0
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? version::implements if?
  973:getproperty *::sender
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String?
  976:getlocal0
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? version::implements if?
  977:getproperty *::const finally
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean
  980:pushbyte -1
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean int
  982:getlocal 4
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean int Boolean
  984:iffalse 993
  988:increment_i
  989:pushbyte 96
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean int int
  991:multiply_i
  992:increment_i
B993:
  993:pushbyte 0
  995:callpropvoid call 9
                        stack:
  999:getlocal 4
                        stack: Boolean
  1001:not
                        stack: Boolean
  1002:iffalse 1104
B1006:
                        stack:
  1006:jump 1123
B1010:
                        stack:
  1010:getlocal0
  1011:getlocal0
  1012:callproperty *::default finally 0
  1016:initproperty *::isPro
                        stack:
  1019:getlocal3
                        stack: Boolean
  1020:iffalse 1104
B1024:
                        stack:
  1024:getlex 632
  1027:pushstring "activatePro"
  1030:getlocal0
  1031:getproperty *::try var
  1034:getlocal0
  1035:getproperty *::isPro
  1038:getlocal0
  1039:getproperty *::email
  1042:getlocal0
  1043:getproperty *::key
  1046:getlocal0
  1047:getproperty *::sender
  1050:getlocal0
  1051:getproperty *::const finally
  1054:findpropstrict Number
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean global
  1056:getlocal0
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean global version::implements if?
  1057:getproperty *::---__-
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean global String?
  1060:callproperty Number 1
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean Number
  1063:pushbyte 0
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean Number int
  1065:getlocal 4
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean Number int Boolean
  1067:iffalse 1095
  1071:decrement_i
  1072:decrement_i
  1073:increment_i
  1074:jump 1090
- 1078:astypelate
- 1079:setlocal3
- 1080:pushscope
- 1081:kill 3
- 1083:declocal_i 3
- 1085:setlocal2
- 1086:getlocal3
- 1087:declocal_i 3
- 1089:coerce_a
B1090:
  1090:pushbyte 109
                        stack: flash.external::ExternalInterface$? String Boolean Boolean String? String? String? Boolean Number int int
  1092:add_i
  1093:increment_i
  1094:increment_i
B1095:
  1095:callpropvoid call 9
                        stack:
  1099:getlocal3
                        stack: Boolean
  1100:iffalse 1118
B1104:
                        stack:
  1104:getlocal0
  1105:getproperty *::isPro
B1108:
                        stack: Boolean
  1108:iffalse 1123
                        stack:
  1112:getlocal 4
                        stack: Boolean
  1114:iftrue 1123
B1118:
                        stack:
  1118:getlocal0
  1119:callpropvoid *::finally finally 0
B1123:
                        stack:
  1123:jump 1143
B1127:
                        stack: Error?
                         locals: * * * * *
  1127:getlocal0
                        stack: Error? *
                         locals: * * * * *
  1128:pushscope
VerifyError: Error #1058: Illegal operand type: * must be version.implements if.
    at dynamic::Firebug()
    at flashfirebug()
    Aug 7, 2012 7:27 AM   in reply to amitchzone
    Hey,
    Author of FlashFirebug here. This seems to be connected to FlashFirebug firefox extension, what version of flashfirebug are you using? Try disabling or uninstalling it and see if the error goes.
    Even better, please contact me via the contact form on flashfirebug site so I can debug it with you as we're unable to reproduce it at all.
    Aug 8, 2012 3:33 AM   in reply to amitchzone
    Hi All,
    Have you tried applying the Adobe patch as described in the following blog:
    http://blogs.adobe.com/flashpro/2012/07/24/unexpected-file-format-erro r-on-opening-flash-files-using-flash-cs5-5/
    Let me know if the problem still persists after applying the patch.
    Suhas Yogin
    Aug 13, 2012 12:18 AM   in reply to Suhas Yogin
    The patch does not work with CS5. Had the same problem with CS5, however the solution was to completely remove FlashFirebug. Now working fine.
    Aug 13, 2012 2:15 AM   in reply to [sami]
    Hey Sami,
    Please try FlashFirebug 4.45 which is in the approval queue. It should solve the problem.
    https://addons.mozilla.org/en-US/firefox/addon/flashfirebug/versions/
    It should be approved later this week I believe. Please let me know if it solves the problem.
    Aug 13, 2012 3:08 AM   in reply to O-Minds
    Installed FlashFirebug 4.45 and working fine
