EdHall754
CS6 workflow (Photoshop, After Effects, Premier Pro)
Jul 31, 2012 7:42 PM
Tags: #photoshop #after_effects #order #cs6 #premier_pro #color_correction #workflow #matte_painting #rotoscoping
Hello, I'm new to CS and have been learning quite a few different programs over the past few months regarding post-production.  I've primarily been using Photoshop, After Effects, and Premier Pro.  I have noticed there are tons of different ways to work within and across these programs through the CS package.  Because there are so many ways to accomplish an end result, I was unsure what is the right way to edit or manipulate video footage.  For instance, if I plan on using after effects to do color correction using color finesse, or matte painting and rotoscoping, what order should I open the files and change them?  Should I start in premier and then use AE, or should I change in AE and then import into premiere?  I noticed not all AE changes are accepted in Premiere. Same question goes with any changes to footage in photoshop as well.  Any advice would be great or at least a direction to look to get resources to help with my workflow.  Thank you.
