When the PCIe 3.0 version of the Areca 1882ix raid controllers are released, I'm going to get one for a 4-6 drive raid 5 array for media and other files. OK, this is a no brainer. But...
What about the other drives? My MOBO has two onboard raid controllers - Intel and Marvell. Besides the raid 5 data drives, the system will have:
- 1 SSD system disk
- 2 WD Velocirapter disks in raid 0 for paging file and media cache
-1 WD Blue disk in a removable bay for archiving
Should these disks be on the Areca? On the MOBO raid controllers? Advantages and disadvantages of each approach?
Dan.
Depends on the number of SATA3 connections you have. A number of motherboards have only two SATA3 connections on the mobo, plus two SATA3 connections on the Marvell chip. In that case I would leave the SSD on a mobo SATA3 port, the two Velociraptors on the Marvell SATA3 ports and the rest on the Areca. If you have 4 SATA3 ports on the mobo, you can consider to have the Velo's on the ICHR ports. The WD Blue can remain connected to any SATA port.
Harm,
Again, thanks for the great feedback.
My P6X58D MOBO has only two Sata3, 6GB/s ports (on the Marvell controller) and six Sata2, 3GB/s ports on the Intel "ICHR10R" Southbridge controller. I'd love to replace the MOBO, CPU, memory, etc. now. Since I build all of my computers, that's a lot of work and I can't spare the time now. So using the current system is a constraint.
Based on your recommendations, it looks like the config should be:
- SSD on Sata3 port.
- RAID 0 Velociraptors on Areca controller using SAS to SATA cable.
- RAID 5 Seagates on Areca controller using SAS to SAS cable.
- WD Blue on Sata 2 port.
This look OK? Any recommended changes?
Many thanks,
Dan.
And not all Marvell SATA 3 controllers support RAID at all. For example, the Marvell SATA 3 controller on the Asus P8P67 Pro motherboard that's currently in my main system has no RAID support whatsoever. Only the native Intel SATA controller(s) on that motherboard support RAID at all.
Martin,
While a single 600gb Vraptor may be "fast enough", I suspect that by simply adding the paging and media cache onto to your 8-drive RAID would perform even better. Just do some testing to help hone your final production setup. I used PPBM5 runs to evaluate various configurations. Don't forget that different media types and project workflows do have different priorities.
Jim
Gentlemen,
It isn't a 600GB Velociraptor. It's two 300GB Velociraptors in Raid 0 configuration. I.e. raid "A" on the Areca controller would be the raid 5 media array. Raid "B" on the Areca controller would be the two disk (Velociraptor) raid 0 array.
Regarding adding the two Velociraptor to the media raid, I wouldn't mind doing that except that I thought that each raid array was limited to the size of the smallest disk. Wouldn't that turn all of the 1 TB drives into 300GB drives?
Dan.
p.s. It should be obvious that I'm not a raid expert. That's why I'm looking for feedback.
Dan,
A 2 x Vraptor 300GB RAID 0 array (600GB array) would be a great supplement to a 8x Areca based RAID 5 array. I would suggest using the RAID 0 for: paging file, media cache, media cache DB, and any render outputs. That will give you lots of speed, and if you were to loose your RAID 0 (they are indeed less reliable than a RAID 5 array, you really have not lost anything at all that is not completely recoverable).
Jim
Jim,
Thanks for the comments. That's pretty much my exact thinking. It's great to get feedback that I'm on the right track.
Up until a few weeks ago, I had a raid 0 set with two WD Black 2TB drives. I wanted speed plus safety, so I got a separate 2TB backup drive and setup up a backup app to regularly back up my data on the raid 0 array.
That worked well except that the backup utility started filling up the backup drive quickly and had to be pruned. Worse, the backup app failed at some point and I didn't notice it. And of course my raid 0 failed.
The only good news is that the raid 0 seemed to partially fail. I suspect that it was losing sectors. I was able to save most of my files on that disk, including most of my still images. And a couple of Pr projects and the most important clips. The bad news is that did lose some images, Pr projects, and clips. Not critical, but damned irritating nevertheless.
I learned a good lesson - never trust complex solutions completely. Raid 0 for non-critical stuff is OK. Raid 5 or better for the important files is the best option, IMO. Like Harm, I'm still wrestling with the fewer, larger disks vs more, smaller disks issue. In any case, I'm thinking about Raid 5 with a hot spare for safety (I believe that's dooable with the 1882ix.)
Dan.
I see you referring to this card as PCIe 3.0 but at least on this page below (if this is the one you're getting), it specifies that its 2.0 instead. Not really sure what speed difference it really would make, but it piqued my curiosity. You should still be getting close to 1000MB/sec reads from your RAID 5, right?
Jake,
You are 100% correct - that's what the page says. However, when I wrote to Areca, they said the PCIE 3.0 versions were in stock at the vendor. When I called ArecaDirect he assured me that they had the new version and I specified that on the order. So I'm keeping my fingers crossed.
That said, my current MOBO only supports PCIE 2.0. I'm buying the 3.0 version to meet future needs and prolong its lifespan. I understand that 3.0 is backwards compatible with 2.0 MOBOs.
Hopefully I'll be able to get by on 1000MB/sec. :-)
Dan.
P.s. My system SSD drive came today! :-)
