Standard panel resizeing using borders
Aug 1, 2012 8:04 AM
Hey all,
Don't take "Panel" too literally. I'm pretty new to flex. Hopefully this is something simple I've overlooked.
I'd like to make a left and right side to my application. A Tree on the left and various dynamic things on the right. I'd like to allow the user to resize the separation between the left and right side in a standard way.
Just about every application us users use allow you to grab a border or area between 2 separated panels and resize them. One panel gets bigger while the other shrinks. This is trivial in c#.NET as a border can be requested and all the resizing is done for you. It's literally drag and drop. I'm trying to find this in Flex if it exists.
Is there a container that supports auto-resizing of areas or even has a way of implementing it in a normalized way? BorderContainer contains no properties I can see to allow resizing, nor the other containers. Should I expect to literally make a HRule or VRule and hand code them to resize panels when clicked (if that's even possible)?
I'm just looking for the easiest way to contain panels with inner resizability.
