CVSMTraining
Captivate Cannot Open File Error
Jul 30, 2012 7:43 AM
VERY simple project is generating error above.
Menu screen with some buttons linked to F4V files inserted as "slide Videos".  The videos are large files and run in 1024 x 768. It saves properly after  a looong time compressing and will not open. This only happens after I've inserted the slide videos and linked to the buttons.
The error says " Cannot open file XXXXX. Ensure that file is not open already etc....."
I've done this a tonne of times before and can't figure out what is happening.
    Jul 30, 2012 8:36 AM   in reply to CVSMTraining
    I'll presume you're using windows, but it should be similar with Mac.
    1) ensure your files are all stored locally.  Saving on network drives will cause some significant delays opening/saving/closing.
    2) look in the folder whre the file is saved and enable viewing hidden files, if it isn't already.  Tools > Folder Options > View > Hidden files and folders > Show hidden files and folders
    3) look for a file names something like ~cp_prj_name_of_project.cptx_lock   If you are confident the file is not open somewhere, delete that _lock file and try to open the project.
    That lock file keeps 2 people from opening the project at once.  Sometimes the _lock file is not cleaned up properly when the project is closed (usually when there's a crash).  Hopefully that fixes it for you.  If not there is a way to try and retrieve the file from backup (if you have backups turned on) or from the cache.
    Any luck?
    Aug 1, 2012 7:59 AM   in reply to CVSMTraining
    Thud...
    You're trying to insert 6 x 1 hour videos (6-800 meg each) into a single Captivate project which ends up being 4.2 Gigabytes in size... and you're wondering why Captivate has decided it cannot open it?
    I think you were right. The file is just too big.
    Aug 1, 2012 8:35 AM   in reply to CVSMTraining
    Just throwing out an idea, do the media files have to be embedded in the captivate swf, or can you link to them as external files?
    Aug 1, 2012 8:46 AM   in reply to AndyKingInOC
    hello,i also met the same problem opening my file~~ I deleted the lock file but still cannot open it still! It's strange that once I tried to open the file, the lock file will appear~~
    Do you know whats the matter? Thank you so much! I need to make changes in my file and only saved one version~<
    Aug 1, 2012 8:56 AM   in reply to wcai
    The lock file should always appear when you open the file.  That's its whole purpose, to keep someone else from opening it while you're editing it.
    If you still can't open it, and it's on a local drive, it's possible the .cptx file is indeed corrupt.  If you have backups turned on (and if you don't, you should), you can try to retrieve it from there.  You can also search for the instructions to retrieve it from the cache files, but that's not always successful
    Aug 1, 2012 10:07 AM   in reply to AndyKingInOC
    Thanks! I will try!
