How do you set Tab Order using the Articles window in CS6?
Aug 1, 2012 8:55 AM
Im seeing that you can set tab order through the articles window but cant find clear instructions on how to do this other than its possible.  Ive set all my items in the proper order I want them to be in the Articles window but when exporting to an interactive PDF, its not flowing in the order that I listed them.
Using the "object/interactive/tab order" window is way to painful if you are working with more than 15 items to organize since you cant stretch that window
    Aug 1, 2012 9:19 AM   in reply to kellyjaye1
    When using the Articles Panel to set tab order, you need to make sure that you are setting up all of your text fields/form items in one Article. Like such:
    Then, on export you need to select both "Create Tagged PDF" and "Use Structure For Tab Order".
    That should be it.
